why do I have to press twice?
LeesKeys
Post by LeesKeys »
I've started using Camelot Pro (IOS) to manage my live keyboard performances. I can set each input on my Quattro to cover various midi cc functions but one function, "Scene change", requires that I press the pedal twice, not once. If I reassign this function to a pad on my Novation Launchkey, the operation occurs instantly with one pad press.
Re: why do I have to press twice?
I assume you are doing this with a switch? Can you post a screenshot of your settings? It's likely related to the values that the pedal is sending. By default a switch will send value 127 when you press the pedal, and 0 when you release it. If however you have 'toggle' enabled, then it will alternate between sending 127 and 0 every time you press and release the pedal, which is likely the issue you are having. However, It's also possible that Camelot Pro doesn't want to see the 0 at all. If that's the case, you can enable 'toggle' and set both Value1 and Value2 to 127 and the pedal will only send 127 every time you press the pedal.
LeesKeys
Post by LeesKeys »
It was set to Toggle. Thanks!
