eDRUMin version 2.1 BETA
eDRUMin version 2.1 is available for testing. Anyone who wishes to downgrade from this version to version 2.0.x or below will have their devices factory reset, so I advise saving a device preset first so you can recover your settings if you need to.
New Features
  • Added Mesh 3 Side Sensor pad type.
  • Positional Sensing for Mesh 3 Side Sensor pad type.
  • Added Roland PDA-120LS factory preset.
Other Changes
  • Fix 'Independent' velocity curve control missing from version 2.0.2.
  • More hardware performance optimizations.
The positional sensing was modeled around a brand new Roland PDA-120LS-BK (the only 3 cone pad I own), so I have no idea how well it will generalize to other 3-cone pads. With the PDA-120LS-BK I find it hard to get 3 well defined positional zones, but center and off center can be differentiated quite nicely. If you have a PDA-120LS or any other 3 cone pad, I'd love to hear about your experiences.
eDRUMin_Control_PC_2.1.0.17.zip
eDRUMin_Control_OSX_2.1.0.17.zip
eDRUMin_Control_LINUX_2.1.0.17.zip
Gemini8026
Re: eDRUMin version 2.1 BETA
Post by Gemini8026 »
My dual mono inputs stopped working. Tried resetting and no luck. Do not appear to be outputting. Everything else is fine.
Mine work here. What pad types are they set as?
hb1980
Post by hb1980 »
Wed Sep 14, 2022 9:35 am
New Features
:o
Looking forward to trying positional sensing on my ATV! Nice one for attempting this Rob, having seen it on the recent m*mic update I dared to dream :-)
Gemini8026 wrote:
Wed Sep 14, 2022 4:14 pm
Confirmed. If the first half of a dual mono input is set to a Mesh or Acoustic trigger pad type, the pad connected to the second half of the dual mono won't trigger. A temporary work around is to set the first half to 'Rubber Pad' pad type. I'll fix it today. Thanks.
UPDATE: Fixed in build 1
so finally it's time to get a 3-sensor snare
excellent
Changes in build 1
  • Fixed issue with Dual Mono inputs.
New Features
Other Changes
eDRUMin_Control_PC_2.1.0.1.zip
eDRUMin_Control_OSX_2.1.0.1.zip
eDRUMin_Control_LINUX_2.1.0.1.zip
Sorry for my confusion. If upgrading to 2.1, do i need to create user presets for each pad OR when the 2.1 control app starts will pull from edrumin mempry of my last saved presets?
Jf450
Post by Jf450 »
Just a heads up. I upgraded to 2.1.0.1 and it changed my bass drum pad type from mesh center piezo to Rubber pad. I was getting weird triggering with the bass drum when hitting my ride at the same time as the bass drum, the bass drum hit would not register. I changed it back and it seems to be fixed.
Jf450 wrote:
Fri Sep 16, 2022 7:47 pm
Thankx I’ll keep an eye 👁 out for that.
Btw, did you select any pad preset for the kick ?
