Roland BT-1 -- Double tap for different command?
bandit614
Post by bandit614 »
Hi -
I currently use a BT-1 (mapped to F#2) to tell my DAW via hotkey to play/pause
Is there a way that a "double tap" or "triple tap" within a certain time frame (1 sec? half a second?) can be programmed in so that it triggers a different midi note or command? (mute/solo/whatever)
Either to the edrumin itself, or via a 3rd party app?
I am using Mac OSX for reference.
Re: Roland BT-1 -- Double tap for different command?
Instead of time you may be more successfully requesting a different MIDI note based on velocity. So a max velocity hit is one midi note and something not max velocity is a different midi note.
There are four banks. Probably wouldn't be too hard to implement something to switch banks given the velocity of a hit.
