Custom Cables
techministry
Custom Cables
Post by techministry »
I'm making a custom snake cable to carry multiple inputs in 1 cable on my edrumin 10. I'm able to achieve this by dedicating 1 ground wire and sharing it on all the sleeves. I've already tested and all 10 front inputs are working fine on a shared ground, but I'm hesitant to try sharing ground on pedal inputs. Rob is it safe to combine ground (sleeve) with front inputs and rear pedal inputs?
Re: Custom Cables
A single common GND connection for all inputs, whether pedal or trigger, should be fine.
techministry
Re: Custom Cables
Thanks.
