OpenClose HiHat to slow
Spinne
Post by Spinne »
I use an edrumin 10 with a Roland TD11. It improves the sound quality. I did not change anything in Superior and the sound is much better!!
But I have one issue: If i play 8th notes with the Stick on the closed HiHat and than open and close the HiHat. Like so:
8th Hihat: x o x o x o x o
(x = closed Hihat, o = open HiHat)
close on the downbeat and open on the upbeat.
There is always the close sound. Can I somehow adjust the reaction speed of the close/open HiHat? Or what have I to adjust?
Thanks
Re: OpenClose HiHat to slow
I'm not entired certain what your problem is, but it sounds like your hihat is not opening quickly enough? Can you post a screenshot of your hihat pedal settings?
Spinne
Post by Spinne »
Yes, it's not opening quickly enough.
I make screenshots next week (the equipment is not avaiable at the moment:-) ).
