Alesis Strike Pro drum map anyone?
Luckymethod
Post by Luckymethod »
I've had a tough time figuring out the drum map cause I can't find the midi spec for the Alesis Strike module, i was wondering if anyone already built one and can share it with me.
Re: Alesis Strike Pro drum map anyone?
I've starting making one based on information inside Superior Drummer 3, but it's really hard to find reliable information regarding which notes trigger what. If anyone can post that information, I'll happily add a map for it.
Chaser
Contact:
Post by Chaser »
Sat Aug 06, 2022 2:03 am
https://www.alesisdrummer.com/index.php ... 6#msg56326
Done. It will be packaged with the next release, but I've attached it here so you can give it a go and let me know if there are any issues.
Importing Presets
Alesis_Strike_Map.edp
(576 Bytes) Downloaded 101 times
Luckymethod
I'll test it as soon as I'm back from vacation, thank you so much Rob.
Luckymethod
I don't know if the issue is the map or the new version of the software but something is amiss, check the video:
https://photos.app.goo.gl/gN6tHXzKX3CceMgS6
I just checked, and yes there's definitely something wrong with the map. Fixed for the next version 2.1 build.
