DDRUM 4 SE single-cable Hi Hat Controller
aarond
Post by aarond »
Hello, Does the Edrumin trigger unit work with a single-cable Hi Hat Controller from a Ddrum 4 SE kit? This only has a single trs output and is described as 'hall effect sensor-based'. Thanks!
Re: DDRUM 4 SE single-cable Hi Hat Controller
I have no idea. The hihat is powered?
Do you mean this hihat?
https://reverb.com/item/15928596-clavia ... -red-black
