Linux Version
Linux Version
Rob,
How hard would it be to get a Linux version of the controller software?
Re: Linux Version
Not easy.
Re: Linux Version
Ok… never mind then. Thanks. I was hoping since you had a MacOS version and cross platform code there would be an easy button for Linux.
I was going to toy with putting it on a Raspberry Pi with a 7” touchscreen.
Re: Linux Version
Well it's not impossible, it's just a lot of work. I have been looking into it, but haven't really made any progress.
Re: Linux Version
I suspect there’s not a lot of need for Linux version. I know SD3 isn’t available for Linux and probably several other VSTs aren’t either. So if you have to have a Windows or Mac around for your VST it may as well run the ED controller software as well.
