Multiple eDRUMin 4's
cfordyce05
Post by cfordyce05 »
With the 10 being out of stock for a while, can I still buy 2 4's and be able to control both for my whole set? I could only find information about plugging a 4 into the host port on the 10 to expand trigger inputs. Do you just plug the 4's into 2 separate USB ports on the computer or into a hub?
Re: Multiple eDRUMin 4's
Yep. I used to run 4 ED4. The control app will see them both. You can assign different colors to them to help distinguish the two units.
cfordyce05
Excellent! Thank you!
negativei
Post by negativei »
To follow up, I’m planning on running 2 edrummin 4s and a E10. Would the signal chain be E10 to usb hub and the E4s also to the usb hub?
Correct.
