sysex pass-thru
kenjwright
sysex pass-thru
Post by kenjwright »
Possibly I am not understanding the manual but it seems to state that the eDRUMin supports System Exclusive pass-thru, and reading that I would expect that any sysex messages sent to the eDRUMin via USB (with some other mfg ID) would be passed through to the MIDI out DIN port and show up on the appropriate device. However that does not happen. For every sysex packet received on USB, what is sent to MIDI-out is the last MIDI message previously sent from a pad strike. What am I missing?
Cheers!
Ken
Re: sysex pass-thru
I'll look into it today. Understandably this is functionality that doesn't get much attention or testing.
Re: sysex pass-thru
Confirmed bug. Fixed for the next build.
kenjwright
Re: sysex pass-thru
:D Thank you!!
Re: sysex pass-thru
Fixed in build 37.
viewtopic.php?f=29&t=1460
kenjwright
Re: sysex pass-thru
Updated to 2.0.0.37 and confirmed that the pass-thru is working now. Whoohoo! One thing I noticed is that the eDRUMin MIDI Monitor is not showing the expected byte count. Possibly I am assuming incorrectly that the number of bytes following F0 up to F7 would be displayed? Currently is showing values of 80,99, or 100 where the actual packet size is a constant 1173 bytes per packet.
Not a show stopper by any means, just an observation.
Thanks again for the rapid update!!
Cheers!
Ken
Re: sysex pass-thru
Thank-you for confirming the fix. To enable sending arbitrarily long sySex messages, the devices breaks them up into smaller packets. The MIDI Monitor is showing the size of those smaller packets. I suppose I can make it suppress displaying all the those messages and instead just send 1 message with the total size when all the packets have been sent--but as you say, it's not a show stopper.
UPDATE: For the next build the MIDI Monitor will just show a single entry with the complete size of the sysEx message.
kenjwright
Re: sysex pass-thru
Confirmed that 2.00.38 sysex now shows the actual packet size and pass-thru is still successful.
Thanks again and AWESOME support!!
Cheers!
Ken
