My Snapshot Manager isn't showing all of my saved snapshots and only able to load the latest 8 used. All the other ones below cannot be viewed or selected. There's no side scrollbar to go up or down and the up/down arrow keys don't work either.
I'm on M1 MacOS Monterey 12.2
MIDI Expression Firmware:2.8.6.12
Thanks!
Snapshot Manager not showing all the saved presets
Re: Snapshot Manager not showing all the saved presets
Ya, the snapshots aren't scrollable. I was too lazy to implement it. I guess I figured no one would need that many. I've got time these days so I guess that's something I can implement.
Thanks for the quick response! That would be great!
MIDI Expression is an indispensable tool! Every VST sample library I acquire I create "snapshots."
I just started using VSL products and the amount of control from their Synchron Player works very well with MIDI Expression.
I've made the snapshots list scrollable in version 2.9. You can check it out here:
viewtopic.php?f=26&t=1509&p=10861#p10861
Thanks, Rob!
I'm able to scroll through the snapshots now with the mouse-wheel!
The option to rename presets is GREAT!
Thanks again for an amazing product!
All The Best!
All The Best!
