2 ED10 Placement? Same side or spread out?
dreinmann
Post by dreinmann »
Getting ready to setup 2 ED10's on my A2E set, replacing a TD12 & TD11. I'm thinking about putting 1 ED10 on one side of the kit, and 1 ED10 on the other side of the kit. I have to rewire anyway to replace the TD11 snake.
My thought is that this will be perhaps a cleaner look, and less of a rats nest of wires all to one place.
Any thoughts or downsides I'm not thinking of?
brave_kilby
Re: 2 ED10 Placement? Same side or spread out?
Post by brave_kilby »
I've set it up that way myself, with the usb cable routed inside the center tube so there is no visible cable crossing from one side to the other.
For now, this setup is actually more messy because I only have long cables, that were tucked in tubes before :lol: I'll need to measure proper lenghts, and once I am happy with positioning I'll just cut and make custom ones so they are not dangling all over the place.
dreinmann wrote:
Sat Mar 26, 2022 5:14 pm
Just a random observation, your kit looks a lot like Simon Philips' kit. Is this a coincidence?
dreinmann
Post by dreinmann »
@MisterE, sooo sorry I ignored this message for a year! It's actually a Mapex M birch.
