Hi Hat link issue
DC1970
Hi Hat link issue
Post by DC1970 »
My eDrumin 10 has decided to make channel 2 into 2 mono hi hats. My hi hat is actually on channel 6. If I try to reset channel 2 shows me a single hi hat. I need to change it to 2 mono tom pads.
It's also showing my hi hat pedal linked to channel 2.
How do I change which channel it's linked to? I guess if I can unlink it it will then allow me to issue the right hardware to channel 2?
Re: Hi Hat link issue
You can unlink it from the pedal editor.
eDRUMin 1.6.pdf - Linking and unlinked hihat cymbal
DC1970
Post by DC1970 »
Thank you - I did work it out in the end but had to head out so couldn't back on to say I'd sorted it :)
