Updating from alpha to BETA
upgrading to build 23 has caused some major GUI issues
- Screen Shot 2022-03-01 at 15.16.51.png (345.36 KiB) Viewed 394 times
Re: eDRUMin version 2 BETA
I think you were probably using the alpha version and skipped over build 9.
Rob wrote: ↑Sat Feb 12, 2022 5:34 amI've posted build 9.
The drum maps now define 32 kit pieces. I had to rearrange the location of stuff saved to EEPROM. As a result, if you are already running version 2.0.0.x on an ED4, you will need to factory reset the device and reload a saved device preset, which you should be able to do without needing to downgrade back to version 1.6. ED10 devices will be unaffected.
After you update to version 2.0.0.9, load a factory drum map onto your devices. Drum maps from version 2.0.0.8 and earlier drum maps will look all mixed up due to changing the number of kit pieces.
Change in build 9
- Increased the number of kit pieces in drum maps, spanning them over two pages.
- Added more kit piece images to choose from.
- Stopped locking the preset list when editing a drum map, and will instead show a confirmation if settings might be lost.
- Possibly fixed an issue when dismissing a confirmation before updating firmware.
