DSP Trigger does not show up in MacOS 12
haugbui
Post by haugbui »
DSP Trigger does not show up at all in Ableton Live 11 under MacOS 12.2.1
I also tried other software than Live, and it did not work.
DSP Trigger works fine in Live 9 under MacOS 10.10.5
Is there a compatibility issue with MacOS 12?
Re: DSP Trigger does not show up in MacOS 12
Have you rebooted? Often plugins won't show up until after a reboot.
haugbui
Post by haugbui »
That did the trick, thanks!
