Hi Rob, I posted this problem under the new Alpha topic but no response there so maybe it should be a new topic. When I edit an input some of the settings aren't saved as I set them. These are: gain, thresh, and hold, and i think crosstalk. I have Auto saved these and when that wasn't working I manually saved just after editing. It looks like the settings have been saved but when i go to anther input and then back to the one i saved the settings have changed ie: I set and saved the hold function to 10.3 and when I switch inputs and then come back it has been changed to 9.7. Same with the other functions for that input- they are not what I saved. I tried saving with Auto input follow disabled and still same problem. Are there some setting ranges that are not allowed? Scan, edge sense, and x-stick seem to hold saved setting ok.
Is this the first you have heard of this? Is it something I am doing wrong? Is there a fix for this next version? The inputs were dual mono. thanks for any help, Mbira
some settings not being saved
Re: some settings not being saved
Even if you don't save and don't have auto save enabled, the settings should stick as long as the device doesn't loose power. I think what you are seeing is related maximum resolution of the those particular controls. Hold time has a resolution of about .4 ms ((100-5)/256). So if you make a small enough change, it won't actually result in different saved value.
ok I will check that out and see if bigger changes are saved. thanks for the response.
so actually the hold function won't change unless i move it at least 1ms. But it will save now. it is a little weird the way it works but probably no problem, thanks.
