Any chance of labels?
Rabidreject
Post by Rabidreject »
Hey rob,
I know I keep asking for stuff for your updates I just think of things and suggest as I personally would find them useful.
Much like the last thing if it’s just me that wants it it’s probably no big deal (annoying for me tho lol) but if other people would find useful as well it may be worth you looking into. That being said…
Any chance of the ability to label each box which represents each input at the top.
When I’m using an ed10 and an ED4 I do find it rather confusing knowing which box is which. It’s mainly for unplugging and plugging everything back in. It’s hard to know which order to put them back in. I understand that you can just hit the pad once it’s plugged in and it brings it up but yeh when you unplug everything and then try and remember what goes where is hard.
I guess I could make a preset (once I get the update coz that naming bug is SUPER ANNOYING - thanks for fixing it rob!)for every drum then it doesn’t really matter I just apply the presets but yeh I guess the reason I havnt is that bug lol.
Just a suggestion!
Thanks
Re: Any chance of labels?
that's weird. I mean, you see the difference between the boxes ... and in the software you have different colours.
It should be easier in version 2. There will be more images available and I'll either have some sort of different coloring options or very tiny 3 or 4 latter labels. Still haven't decided.
Rabidreject
Ah ok great. So it is something you have thought of yourself as well. As I say, it’s not a completely needed thing, it would just be helpful
Ah, ok, sorry. I was completely off the track.
You meant the icons of the inputs, on the buttons.
Haha. I read boxes and ...ya..
Did you think of tooltips or an area where the labels pop up
hovering over the button.
Rabidreject
‘Did you think of tooltips or an area where the labels pop up
hovering over the button.’
Definitely a tidy suggestion
