Cannot reset inputs
DC1970
Cannot reset inputs
Post by DC1970 »
I've got channels 6 and 8 and they're showing Bell on the input selector and Roland 3 Zone Cymball Bell Input on the main screen with the edit screen behind it greyed out. I want to reset these but the reset input doesn't seem to work. Running 1.6.2.6
Any clues?
Re: Cannot reset inputs
Try resetting, saving if auto-save.is off, and then power cycling the unit.
Just to be clear, you need to reset inputs 5 and 7 as they are controlling inputs 6 and 8.
DC1970
Post by DC1970 »
Thank you, I'll give that a go and report back with my findings.
DC1970
Post by DC1970 »
Resolved.
I had to change the pad type of 5 and 7 to dual zone. They were set to 3 zone. This then removed the bell option freeing up channels 6 and 8.
