Hey Rob.
I know your SUPER busy but I wondering how hard it would be to add a back or undo action button?
It would be useful to go back sometimes when I’m Fiddling with settings and obviously don’t note all numbers of what I’m doing every time I change anything.
Hope that makes sense. Still love the product. So incredibly versatile.
Thanks again
Undo or back button
Re: Undo or back button
Workaround. Turn off auto save before making changes. Make your changes. If you like them then auto save on. If you hate the changes cycle power to your unit and it will revert to the last state that was saved.
Not easy to do. Dadwrshpdrum's suggestion is you r best bet. Maybe I can add a ctrl-click option to the save button to revert settings to the last saved state.Rabidreject wrote: ↑Fri Feb 04, 2022 3:30 pmHey Rob.
ah thats a very good work around actually! Ill do that, ill just have to remember to click save if I find what I like!
"Maybe I can add a ctrl-click option to the save button to revert settings to the last saved state." - I persoanlly think that would be incredibly useful but shit, if im the only one, its probably just me!
Honeslty I suppose its not hugely Important. its more at the beggining when first getting it and you are constantly trying to dial in all your settings. I find as I use it for longer and longer I am ironing out the creases anyway so its kind of ok.
Thanks for the reply - you really are bang on it Rob!
