Will KAT hi hat and kick triggers work?
Bucky
Post by Bucky »
Will KAT hi hat and kick triggers work with eDRUMin?
Thanks,
Evan
Re: Will KAT hi hat and kick triggers work?
Not sure. Can you post links to the products?
Bucky
Post by Bucky »
If anyone can help with this question I would appreciate it. I bought the eDRUMin and I need to know what Hi hats will work with it.
I don't actually know because I don't own one, but it's extremely likely that it'll work fine unless KAT is doing something very strange with their design. Certainly if their gear is compatible with either Roland or Yamaha modules, then it'll work fine. From the looks of that hihat, it appears to a Hall Sensor design very similar to the ATV hihat, which is supported.
Bucky
Post by Bucky »
Yeah, I think I'll give it a shot and then we'll know.
Appreciate the thoughts!
