Can edrumin 10 be selected in multiple instances of Battery 4 or other software?
mrmbira
Post by mrmbira »
Hi, I am not sure if this is a function of edrumin10 or of the software i am using. Can edrumin 10 be selected in multiple instances of Battery 4 or other software as a midi in device? On my setup in the midi settings of battery 4 , when I have edrumin selected for midi in on one instance then try to select edrumin for midi in for another instance of battery 4,it is not possible to turn it on.
I want to use a foot switch in edrumin to change banks but each bank has to be in a separate instance of Battery 4 as there is no more cells for more banks. I am not sure this is a battery 4 issue because some other midi in devices are able to be enabled in more than one instance? Any thoughts? thanks, Mbira
hang12
Re: Can edrumin 10 be selected in multiple instances of Battery 4 or other software?
Post by hang12 »
mrmbira wrote:
Sat Jan 29, 2022 9:30 pm
You don't mention what OS or hardware you are using.
The eDRUMin can send out triggers on multiple MIDI channels, and as long as it is defined as a multi channel MIDI 'instrument' on a computer system, it should then be recognized by a VST/AU host (DAW, sequencer, etc.) as a multi-channel device, which you could then assign multiple tracks on various channels to trigger the various instances of Battery 4.
I use the eDRUMin as a controller for multiple instances of SD3 on separate MIDI channels, typically using Digital Performer as the host.
mrmbira
Post by mrmbira »
thanks hang12, I have an older laptop running win7 64bit. I have always run Battery 4 as stand-alone instances. I guess I should explore if I have enough memory and power to run them as plugins in a DAW. Maybe it would use less resources???
I am also looking into midi-ox as a way to be able to get midi from edrumin to each instance of Battery. Has anyone else made this work?
thanks again, Mbira
mrmbira
Post by mrmbira »
Apparently this is a problem with windows OS allowing your midi controller to control only one app. But somehow some of them bypass this and are able to control multiple apps. Midi-ox does solve the problem though so all is good.
so the idea with MIDI OX is already a good one.
Additionally, you need LoopMIDI
https://www.tobias-erichsen.de/software/loopmidi.html
And then this
https://www.youtube.com/watch?v=_QqlmD-uWG4
I think, that will work:
You route/clone the eDRUMin MIDI data to the virtual MIDI ports, let's say loopMIDI_Batt4_#1 and loopMIDI_Batt4#2
and these virtual ports should appear in your Battery 4 MIDI config.
Or you grab Reaper or Cubase, Ableton Live ...
I use Cubase Elements 10.5, Ableton Live 11 and Cantabile 3.0. I startet with Plogue Bidule to more that one instance of EZDrummer2.
Now I do all the routing in Cantabile 3.0.
Cantabile 3.0
Cantabile 3.0
Plogue Bidule
Plogue Bidule
MIDI OX
MIDI OX
Hope that helps!
Manuel
Oh, I forgot:
You have to select the input and output devices:
MIDI OX - Devices
MIDI OX - Devices
mrmbira
Post by mrmbira »
thanks Manuel, I will look into this. I would like to figure out sending kit changes to battery too.
