Hi all,
Just came across these products as a potential solution for something in my studio. I haven't done much work with MIDI hardware so any advise is much appreciated.
What I'd like to be able to do is control my talkback function on my UAD Apllo x8 via a handheld switch. Switch would be something like this:
https://www.pacrad.com/switchcraft-e903 ... ntary.html
Ideally there would be one in the front of my room and one at the back so 2 switches to convert to the same MIDI channel
I'm wondering if a switch like this could then be converted to midi through the MIDI Expression Quatro or IO plugged into my computer and then by using https://www.raduvarga.com/software/ua-midi-control I could tell that midi channel to activate the talkback signal in Console.
Thanks for any help or council have a good one!
Tyler
Talkback Handheld Switch.
Re: Talkback Handheld Switch.
That should definitely work. I have a couple DIY hand help switches I use from time to time.
