Lemon Cymbal Cleaning Tip
Hi buddies!
I just used the very best method to clean your Lemon cymbals having those grooves in the rubber surface.
Look at that:
I did a tiny video. I saw some ads on Amazon and thought like... hmmmm ... if that thing goes into every pore it would be great
for porous, grooved surfaces and .... woooow. Awesome.
And it's awesome on sample pads and MIDI pad controllers, as-well.
https://drive.google.com/file/d/1smo52R ... sp=sharing
It feels like cleaning your cymbals with a breast implant ... :D
Greetings
Manuel
Re: Lemon Cymbal Cleaning Tip
I'm always interested in good methods to keep gear clean and maintained. I think all equipment lasts longer and works better if you do. I'm going to order some Cyber Clean to try it.
I've been using 303
https://www.amazon.com/gp/product/B00KN ... UTF8&psc=1
This should not be an advertisment. Take something ... But I was sooo happy. I really like clean, black eCymbals. :D
