Hi everyone,
I´m fine tunning my hihat (2 zones metal cymbals) and when I close my hihat after hitting it once fully open, when I close it afterwards, SD3 register a "closed pedal articulation" but also a "closed edge articulation". If I only play it with my pedal everything is fine and I get only the closed pedal articulation. It only happens after hitting it with the stick.
The weird thing is that my eDRUMin doesn´t recognize it as a hit on my hihat cymbal input page, when I press down the pedal (the hit on the print screen is the fully open hihat hit), only SD3.
I tried with a max hold time because I thought that was a re-triggering issue, but the poblem remains, also with a high threshold on the hihat input page. I maxed the "xTalk" on the pedal page.
Is that normal and I´m just being picky?
SD3 Hihat close pedal
- image.png (282.41 KiB) Viewed 782 times
- image.png (86.67 KiB) Viewed 782 times
- image.png (177.12 KiB) Viewed 782 times
Re: SD3 Hihat close pedal
Hard to be sure what the issue is, but start with setting the gain properly on your hihat pedal. A setting of 1 is almost certainly to low. You'll find that as you bring up the hihat pedal gain control, you'll be able to turn down the xtalk control.
Also, you might want to relax your hihat cymbal decay control, hard to tell for sure, but it looks a little aggressive to me.
I followed your suggestions and the problem remains.
Can it be related to cc messages/values, causing another articulation to trigger?
I can't reproduce the issue here. Can you use MIDI-OX or some other MIDI monitor to see if the edge note is indeed coming from the eDRUMin?
I think it´s an SD3 problem. It doesn´t happen on any EZX libraries, only on SDX expansions. Although it´s not audible. I changed the velocity curve for that articulation and it´s not audible even with a very exaggerated curve. Strange...
