Velocity Layers with eDrumIn
Hi!
Sorry, guys. I was 100% sure, that Superior Drummer is able to play different ariculations for various
velocity layers. But somehow I don't get it.
I would like to trigger a Bow Tip for e.g. velocity 0-50 and a Bow Shank at 51-127.
Anyway, woudn't that be a nice feature build into the edrum, being able to trigger different notes for different velocities?
Just a guess ...
Greetings
Manuel
Re: Velocity Layers with eDrumIn
SD3 can… You have to create a stack on the cymbal. Right click the cymbal and select More… then select Add To… then select Bow Tip. When the Search for Instrument dialog pops up select Bow Shank in the list on the lower right and click the Stack on Bow Tip.
Now that you have your stack you can pick each individual articulation and assign a Velocity Gate to it.
Ahhh, dude! Thank you!
I knew that on stacks it's working but I didn't that I can stack only specific articulation.
Wow, this piece of software is really 👌
