technical questions
Vadrums
technical questions
Post by Vadrums »
Hi Rob
I am writing to you from Belgium. I have two Roland TD11 & TD4 modules which work very well connected to my iMac in usb with Superior Drummer 3. All my connections to the two modules are busy. So I was thinking of the Edrumin 4 because I just want to add 4 cymbals like the Roland CY5 or CY8. But I also have 4 Roland PD6 pads (black) NOT THE PDX6 !!! that I could possibly use as cymbals.
My first question is: from my usb connections to my Mac, if I connect the Edrumin directly on a HUB to my iMac will it work?
Second question: are the Roland PD6 compatible with the Edrumin 4?
Third question: is it possible with the Edrumin 4 to separate the cables? You will find pictures of all my explanations.
Thank you very much for reading me and being so kind to answer me.
Greetings from Belgium. :D
Re: technical questions
The answers to your questions are yes, yes, and yes. The control application has presets for the PD6 pads, btw.
Vadrums
Post by Vadrums »
Many thanks Rob for your answer.
I go to by the Edrumin 4.
Best regards
Vadrums
Post by Vadrums »
Hi Rob
Other question : edrumin 4 worked with Yamaha PCY95AT E-Cymbal ?
Thanks for tour answer
Best regards
Should work fine.
Vadrums
Post by Vadrums »
Hello Rob,
I would like to buy a Roland VH12 hi hat and I bought a year ago the EDRUMIN 4. I am very happy with it.
My question is: Is the Roland VH12 hi hat compatible with the EDRUMIN 4?
Thanks for your answer.
Yes, although calibrating it can be a bit tricky.
Vadrums
Post by Vadrums »
Is more easy with the vh13 ?
Thanks
Yes, but there's a write up in the manual about setting up the VH-12, and although I've never used a VH-12, it's my understanding that it performs just as well as the 13.
