alesis dm10
christian
alesis dm10
Post by christian »
hi ...before i buy it i got few question...first i got a alesis dm10 mode and a2e converted kit i also use ezd2 only in stand alone mode in my living room for my self ...im not playing gig or with people.....iplug my drum module in a audio iinterface....if i buy it can i use it with my audio interface or it better to ug my module direct in usb port of my pc ...its a new pcq i buy only to run ezd2 in stand alone...i do not have a daw ...can i use it with out a daw ....and if i buy it the dsp will help me to have a better triggering range a better dynamic and my hihat gonna performe better?
Re: alesis dm10
DSP Trigger does not support hihat controllers and cannot be used without a VST host. I think you should look at eDRUMin. It will do everything you need.
www.audiofront/eDRUMin.php
