Positional sensing
beforethewomb90
Positional sensing
Post by beforethewomb90 »
I’m new to the e-drum scene. What software supports positional sensing? I have a custom e-drum snare pad that has the capability. I have KOMPLETE from Native Instruments which includes Studio Drummer that I’ve been using, but it doesn’t seem to support positional sensing? Was trying to stay away from buying a drum module and I actually have the edrummin on it’s way. But in the meantime I’m trying out DSP Trigger.
Re: Positional sensing
Superior Drummer 2 and up and BFD 2 support positional sensing for sure.
Some drum apps might not support CC4 for positional sensing but will have separate center and off center sounds. You can then configure the positional sensing to send a separate note instead of CC4, allowing you to trigger both sounds.
beforethewomb90
Excellent, I'll look into it! Thanks for the quick reply Rob!
