Alesis Nitro Mesh adjustment support
emuller
Post by emuller »
Hi Everyone!
I just got my edrummin 10 last week and I'm really excited! However I am still far away from getting my new drum kit. For context, I started using edrums during the pandemic. Since I was not completely convinced at the moment I decided to go for a cheap Alesis nitro mesh to test it. I was not thrilled with the sound quality, but I was of how quiet they were. That's why I decided to convert an acoustic drum set into an e-drum, using a VST/DAW + edrummin 10.
My issue right now is that I have my Alesis nitro mesh for the next 6 months and I would like to get the most out of it with edrummin 10 while at the same time learning how to use edrummin so that I have already passed the learning curve when I finish my new converted set.
My first question would be, has anyone had the experience using the alesis nitro mesh with the edrummin 10? any recommendations would be highly appreciated. Also, if you have presets for it would be great if someone could share it with me.
I know this is a bit of an open question, but I would like to start this way to get all possible answers, and then focus on the specific topics. I will probably also open a new thread for the recommendations of the new converted kit.
Thanks in advance for your commments!
Re: Alesis Nitro Mesh adjustment support
There are no presets for your pads, so you'll need to learn how to setup a pad on your own. It's pretty easy once you take the time to learn.
Here are some helpful videos:
Transient Scan Controls
https://www.youtube.com/watch?v=v9_w32TWKZ0
Rimshot Range
https://www.youtube.com/watch?v=zkNsBkd4x-E
Edge Sense
https://www.youtube.com/watch?v=85IwnQrVRSI
