RHH135
BenoitL
RHH135
Post by BenoitL »
Hello
I'm new on eDrumin I ve a RHH135 with 2 zones (2 zones open and 2 zones closes + foot)
Do you have advice to connect RHH135 on eDrumin 10 ?
or Preset ?
Thank you !!!
Re: RHH135
Use one of the Yamaha HH65 presets and then use the 'LINK' button to link the pedal and cymbal.
BenoitL
Re: RHH135
Post by BenoitL »
Thank you Rob > I will try now !!
BenoitL
Re: RHH135
Post by BenoitL »
Thu Aug 19, 2021 10:38 pm
Hello
Where can i find the Yamaha HH65 preset ? I dont see it on the list
thank you
>>> I find it !!!
ghanashyama
Re: RHH135
Post by ghanashyama »
Hello,
I'm also interested in this topic, I planned to buy the edrumin and I'd like to now if I'll have to change hihat or not...
Have you successfully configure it?
Re: RHH135
You don't have to use a preset (I never have). Calibration is generally super easy.
