Bell input gets stuck after setting a 3 zone Roland
The bell input gets stuck after setting a 3 zone cymbal with 2 cables, if you want to reuse that input with another pad/cymbal in dual zone with bell sense, you can't reset the input because it's greyed out and sometimes with an exclamation mark, restarting the app or disconnecting the edrumin won't do it, so what you need to do is unplug the "bell" cable, power cycle the edrumin, plug the "bell" cable again and now you will be able to reset it and set it up again as another pad/cymbal
Re: Bell input gets stuck after setting a 3 zone Roland
This has been fixed in version 1.6.
