Pad to converters without preamp
ds11
Post by ds11 »
Great product idea! I'm looking forward to testing it out after getting a kit together, but must first plan out the whole signal chain.
Have you tested DSP Trigger or heard of it working with pads plugged directly into dedicated A/D converters that do not have built-in preamps? Just wondering if the signal will be sufficiently loud to be processed by the software.
Thanks!
Re: Pad to converters without preamp
Ya, the signal will be sufficiently loud. In fact, you shouldn't be trying to put the signal through a premap.
