Roland 3 Zone Cymbal Bell input
dp
Post by dp »
Hey there,
perhaps a stupid question but i have a problem with two of my inputs. Both of them say they are Roland 3 Zone Cymbal Bell inputs, but i don´t have any cymbals plugged in.
All other inputs are mesh center piezo, so can anybody please tell me how to change these ports in mesh center piezo too?
I would be so thankfull for a solution.
Greets Daniel
Screenshot (1).jpg (389.49 KiB) Viewed 660 times
Re: Roland 3 Zone Cymbal Bell input
What's the input prior set to? If they're Roland 3 zone, set to dual.
Screenshots will help.
dp
Post by dp »
hey thanks for your quick answer,
it´s all set to mesh center or side piezo.
perhaps my screenshot helps?
dp
Post by dp »
a factory reset solved my problem, everything works fine again!
Thank you
That's a bug. Was that the result of a firmware update?
dp
Post by dp »
Hey Rob,
it appeared in version 5.0.16, but i can´t tell you exactly if it happened after the update from 5.0.15.
now I´m running 5.0.20, after updating to this version nothing changed.
Than i did a factory reset and it worked again.
Thanks for your excellent work
Greets
