Midi expression with hot hand 3?
volt4k
Post by volt4k »
Hot hand 3 work as an wireless expression pedal, here is the link http://www.sourceaudio.net/products/hot ... thand3.php
i know there is an hot hand usb that work with midi, but i would like to know if i can use the hot hand 3(the one for pedals) with the midi expression to be able to use it in an DAW as well.
Re: Midi expression with hot hand 3?
Interesting product. As far as I can tell, MIDI Expression should play very nicely with it.
