How do you get the edrumin to trigger the closed pedal articulation in SD3? I’ve set the “pedal” note to match the closed pedal note in sd3 but every time I close the pedal I trigger the
bow note. Should I be using certain configuration settings?
Closed pedal SD3
Closed pedal SD3
- C4E3D835-6E39-4291-B400-AD6C63101009.jpeg (290.79 KiB) Viewed 441 times
- B589EC0D-1548-4A34-937E-6B3EBEF1D071.jpeg (312.36 KiB) Viewed 441 times
Re: Closed pedal SD3
G#1 is correct.
Are your hats mounted physically moving? If so, it sounds like a crosstalk issue where the bow trigger is sending the signal as they close.
If they're not, I'm unsure. Could still be a physical movement issue though depending on your mounting. Disconnect your hat trigger to rule it out.
His pedal isn't calibrated properly. The pedal position must return to below about 30 in order for a new closed pedal to be issued.
The hats are physically moving. I have an fsr diy controller in between my hats. I’ll try increasing crosstalk. Also try to recalibrate. So under 30 will trigger a closed pedal note? Thanks.
