Any plans for drum maps for Steven Slate Drums?
I'm using SSD5 free version and considering the full version. With a tight budget this seems like a decent value but, as a newcomer to many topics here, maybe I'm missing the extra features Superior drummer, addictive drummer, bfd have. Anyway, any thoughts on drum maps for SSD? Thanks.
Re: Any plans for drum maps for Steven Slate Drums?
I tried to download a copy of the SSD5 for this exact purpose, but a downlead link was never emailed to me. If you can tell me default mapping, I'll add the map.
I’m away from the computer for the weekend, but I can send next week. This request is reasonable, but note SSD5.5 added a MIDI learn capability which makes creating a user defined midi map super easy.
Edit: for SSD5.5 you find the articulation you want to map and then you hit learn then hit the pad.
Good to know. At my basic level I'm sure it will help. I'm going to post another topic on the difference between these drum programs as that gets away from the original topic here.Thanks.
I took screenshots of the default SSD5.5 Midi map. See attached.Dadwrshpdrum wrote: ↑Sat Jun 12, 2021 1:23 pmI’m away from the computer for the weekend, but I can send next week. This request is reasonable, but note SSD5.5 added a MIDI learn capability which makes creating a user defined midi map super easy.
- SSD5_5 Default MIDI_3.png (604.41 KiB) Viewed 557 times
- SSD5_5 Default MIDI_2.png (604.73 KiB) Viewed 557 times
- SSD5_5 Default MIDI_1.png (602.52 KiB) Viewed 557 times
and the rest.
- SSD5_5 Default MIDI_6.png (608.26 KiB) Viewed 556 times
- SSD5_5 Default MIDI_5.png (604.19 KiB) Viewed 556 times
- SSD5_5 Default MIDI_4.png (601.36 KiB) Viewed 556 times
Thank-you. l'll add this tomorrow.
Great. Thanks
Here's what I've got. I added maps for the percussion sounds to. Does anyone know the default notes for percussion sounds on Roland moduules?
