Alesis Strike Pad
MrBananas
Alesis Strike Pad
Post by MrBananas »
Hey guys, I just ordered an edrumin10 and I'm intending to configure Alesis strike pads and cymbals initially when I receive it, among other things. I'd be happy to share presets once I have everything dialed. According to Alesis, the Strike pads use multiple censors, which is pretty vague. I read in the edrummin manual that it is sometimes best to set the pad type properly prior to plugging the pad in, but I'm not quite sure what kind of pad the Strike pads would be considered. Does anyone have insight?
Re: Alesis Strike Pad
I think they are probably best supported using the Mesh Side Piezo preset.
