Connecting 2 eDRUMin 10 together
Superfish
Post by Superfish »
i have just ordering my second eDRUMin 10, and need to know how to connect them together.
Is it via the "host USB" to "host USB" on the second eDRUMin 10, like daisy chain?
or do i need a separate USB hub now with 2 units?
Re: Connecting 2 eDRUMin 10 together
Let’s say your current ED10 is called A and you new one is B:
Then... from USB on ED10 B to USB-Host on ED10 A. So you will need a little patch cable that goes from Type-A to Type-B. I bought a 6” to keep the cable mess down.
Superfish
Post by Superfish »
Mylo wrote:Let’s say your current ED10 is called A and you new one is B:
Thanks Mylo ;)
and a great setup with nice short cables there.
And i can see no need for power supply even with 2 units.
Thanks Mylo ;)
That’s correct... no extra power supply required.
Use the eDRUMin B for your hihat.
