Rim Gain
Memorex
Rim Gain
Post by Memorex »
Hi everyone. I´m having some issues with a side mounted trigger (2-zones). I can have a decent signal for the head but I don´t have any rim signal. Is there any way to increase the gain of the rim? Thanks!
Re: Rim Gain
that's what the scalers are for.
Re: Rim Gain
If you don't have any signal then it's probably I wiring issue.
Memorex
Re: Rim Gain
Post by Memorex »
Solved! I installed the trigger again and everything seems normal now
