MIDI Expression 2.8.6 BETA is available
MIDI Expression 2.8.. BETA is available for testing. If you notice any issues, please reply in this thread and I will address them. I will maintain the links in this post to point to the latest build. Your feedback is much appreciated.
https://www.audiofront.net/ME_Control_PC_2.8.6.4.zip
https://www.audiofront.net/ME_Control_OSX_2.8.6.4.zip
New Features
  • Added 'sensitivity' control to fine tune responsiveness of expression pedals.
  • Added 'Dead Size' control for pitchbend to assist returning pitch to exactly center.
  • Added ''Relative' positioning for ribbon controllers.
  • Switches in Dual CC mode can now send 127 followed by 0 or just 127
Improvements
  • Calibration range control is now a lot bigger and easier to fine tune.
  • Added sections about Ribbon Controls, Rotary Encoders, and parameter feedback to the user manual.
Bug Fixes Since version 2.8.5
  • Fixed a parameter feedback issue noticeable when using host automation.
  • Fixed an issue with using the transformer to duplicate and transpose.
  • Fixed various UI quirks.
