MIDI Expression I/O with Ableton live AND Kemper rack
pdupont
Post by pdupont »
HI
I am interested by the product Midi Expression I/O .
I play Guitar with a kemper rack and Ableton live ( backing track ) on PC : i use only a MIDI controler for the two with MIDI IN OUT for Kemper
and MIDI THRU for live ( via a Focusrite 8i6 ). It's work fine.
But i can connect only one EXP on my MIDI controler , its too few.
After looking all your videos and manuals , I think i can use up to 4 EXP connected for controling of Ableton live via usb or MIDI OUT : right ?
That is my question : Is it possible via MIDI OUT to use up to 4 EXP connected for controling Ableton live and Kemper in the same time ?
Thank you for all
Best regards
Philippe
Re: MIDI Expression I/O with Ableton live AND Kemper rack
It's hard to tell from your limited description of your setup, but it sounds like the iO will suit your needs nicely. The MIDI routing of the iO is very flexible. Any pedal can send its MIDI data via the USB and/or the MIDI Out DIN (default is both). Also the data from the MIDI In DIN can be routed to your computer via the USB and/or the MIDI Out DIN (default in USB only).
