eDRUMin version 2 Alpha
Rabidreject
Re: eDRUMin version 2 Alpha
Post by Rabidreject »
sorry I thought I attatched the screen shot...
oh also, you see my ride cymbal in slot 1 and 2? the greyed out box of no 2 always has an ! in the bottom right hand corner but it plays perfectly and when I hit it the ! goes away but then comes back its really weird and its not just this version either it was liek that with 1.6 too
Screenshot 2022-02-13 at 11.58.14.png (237.72 KiB) Viewed 1492 times
Rabidreject
also are the cymbals meant to be floor toms in the new version??!
Screenshot 2022-02-13 at 14.22.47.png (686.29 KiB) Viewed 1492 times
Sun Feb 13, 2022 1:46 pm
You can still roll back to version 1.6 and load them that way. I tested loading a version 1.6 preset in version 2, though, and it seemed to work fine though. I just tested again and it looks like you are right. I will fix it tomorrow.
Hi Rob!
Thank you so far, but anyway when I import the 1.6 device snapshots everything looks kinda weird and
these where not my settings.
So I can load the old 1.6 input presets but not my todays device snapshots from the v2 build before the EPROM thing.
Is it possible to extract the trigger and pedal settings from the device snapshots.
And - yes the cymbals are floortoms ... ;)
20220213_eDRUMin10.edp
(3.84 KiB) Downloaded 99 times
20220213_eDRUMin4_RED.edp
(3.84 KiB) Downloaded 94 times
20220213_eDRUMin4_BLUE.edp
(3.84 KiB) Downloaded 109 times
Rabidreject
lol good its not just me with 7 toms on screen! haha
Anyway Rob it keeps crashing still and I realised there was loads more of the crash log that was out of view in the screenshot so here you go:
Please tell me if im doing something wrong!
** I put your crash log in code tags so it's formatted nicely -- Rob
Code: Select all
Process:               eDRUMin [15330]
Path:                  /Applications/eDRUMin.app/Contents/MacOS/eDRUMin
Identifier:            com.audiofront.eDRUMin
Version:               2.0.0 (16)
Code Type:             X86-64 (Native)
Parent Process:        ??? [1]
Responsible:           eDRUMin [15330]
User ID:               501
Date/Time:             2022-02-13 21:27:54.846 +0000
OS Version:            macOS 11.6 (20G165)
Report Version:        12
Bridge OS Version:     5.5 (18P4759a)
Anonymous UUID:        B70ECEA2-6CBD-0E11-C269-2E00B4648F10
Time Awake Since Boot: 32000 seconds
System Integrity Protection: enabled
Crashed Thread:        0  Dispatch queue: com.apple.main-thread
Exception Type:        EXC_BAD_ACCESS (SIGSEGV)
Exception Codes:       KERN_INVALID_ADDRESS at 0x00000000000007d8
Exception Note:        EXC_CORPSE_NOTIFY
Termination Signal:    Segmentation fault: 11
Termination Reason:    Namespace SIGNAL, Code 0xb
Terminating Process:   exc handler [15330]
VM Regions Near 0x7d8:
    __TEXT                      10f3f0000-10f6fc000    [ 3120K] r-x/r-x SM=COW  /Applications/eDRUMin.app/Contents/MacOS/eDRUMin
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0   com.audiofront.eDRUMin        	0x000000010f42796c MED_Layout::processBuf(int, packetBuf) + 6162
1   com.audiofront.eDRUMin        	0x000000010f4551c9 handleHIDPackets() + 669
2   com.audiofront.eDRUMin        	0x000000010f4e7a30 Editor::idle() + 76
3   com.audiofront.eDRUMin        	0x000000010f4558a1 -[AppDelegate idleTimer:] + 121
4   com.apple.Foundation          	0x00007fff213f9e0f __NSFireTimer + 67
5   com.apple.CoreFoundation      	0x00007fff20641be9 __CFRUNLOOP_IS_CALLING_OUT_TO_A_TIMER_CALLBACK_FUNCTION__ + 20
6   com.apple.CoreFoundation      	0x00007fff206416dd __CFRunLoopDoTimer + 927
7   com.apple.CoreFoundation      	0x00007fff2064123a __CFRunLoopDoTimers + 307
8   com.apple.CoreFoundation      	0x00007fff20627e13 __CFRunLoopRun + 1988
9   com.apple.CoreFoundation      	0x00007fff20626f8c CFRunLoopRunSpecific + 563
10  com.apple.HIToolbox           	0x00007fff2886f1f3 RunCurrentEventLoopInMode + 292
11  com.apple.HIToolbox           	0x00007fff2886ef55 ReceiveNextEventCommon + 587
12  com.apple.HIToolbox           	0x00007fff2886ecf3 _BlockUntilNextEventMatchingListInModeWithFilter + 70
13  com.apple.AppKit              	0x00007fff22e30172 _DPSNextEvent + 864
14  com.apple.AppKit              	0x00007fff22e2e945 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1364
15  com.apple.AppKit              	0x00007fff22e20c69 -[NSApplication run] + 586
16  com.apple.AppKit              	0x00007fff22df4e6c NSApplicationMain + 816
17  com.audiofront.eDRUMin        	0x000000010f3f2964 start + 52
Thread 1:
0   libsystem_pthread.dylib       	0x00007fff2052d420 start_wqthread + 0
Thread 2:
Thread 3:
Thread 4:
Thread 5:
0   libsystem_kernel.dylib        	0x00007fff204fc2ba mach_msg_trap + 10
1   libsystem_kernel.dylib        	0x00007fff204fc62c mach_msg + 60
2   com.apple.audio.midi.CoreMIDI 	0x00007fff34f56bd6 XServerMachPort::ReceiveMessage(int&, void*, int&) + 94
3   com.apple.audio.midi.CoreMIDI 	0x00007fff34f87473 MIDIProcess::MIDIInPortThread::Run() + 111
4   com.apple.audio.midi.CoreMIDI 	0x00007fff34f6d4e2 XThread::RunHelper(void*) + 10
5   com.apple.audio.midi.CoreMIDI 	0x00007fff34f6e65b CAPThread::Entry(CAPThread*) + 77
6   libsystem_pthread.dylib       	0x00007fff205318fc _pthread_start + 224
7   libsystem_pthread.dylib       	0x00007fff2052d443 thread_start + 15
Thread 6:
0   libsystem_kernel.dylib        	0x00007fff204febb2 __semwait_signal + 10
1   libsystem_c.dylib             	0x00007fff2047ec1a nanosleep + 196
2   libsystem_c.dylib             	0x00007fff2047eb14 usleep + 53
3   com.audiofront.eDRUMin        	0x000000010f45578e expressTimerAsThread() + 90
4   com.apple.Foundation          	0x00007fff213b1437 __NSThread__start__ + 1068
5   libsystem_pthread.dylib       	0x00007fff205318fc _pthread_start + 224
6   libsystem_pthread.dylib       	0x00007fff2052d443 thread_start + 15
Thread 7:: com.apple.NSEventThread
2   com.apple.CoreFoundation      	0x00007fff2062949f __CFRunLoopServiceMachPort + 316
3   com.apple.CoreFoundation      	0x00007fff20627b7f __CFRunLoopRun + 1328
4   com.apple.CoreFoundation      	0x00007fff20626f8c CFRunLoopRunSpecific + 563
5   com.apple.AppKit              	0x00007fff22fb623a _NSEventThread + 124
Thread 8:: AMCP Logging Spool
0   libsystem_kernel.dylib        	0x00007fff204fc2f6 semaphore_wait_trap + 10
1   com.apple.audio.caulk         	0x00007fff285ee8da caulk::mach::semaphore::wait_or_error() + 16
2   com.apple.audio.caulk         	0x00007fff285db836 caulk::semaphore::timed_wait(double) + 110
3   com.apple.audio.caulk         	0x00007fff285db784 caulk::concurrent::details::worker_thread::run() + 30
4   com.apple.audio.caulk         	0x00007fff285db502 void* caulk::thread_proxy<std::__1::tuple<caulk::thread::attributes, void (caulk::concurrent::details::worker_thread::*)(), std::__1::tuple<caulk::concurrent::details::worker_thread*> > >(void*) + 45
Thread 0 crashed with X86 Thread State (64-bit):
  rax: 0x0000000000000000  rbx: 0x00007fb5c583ac00  rcx: 0x000000010f569350  rdx: 0x00007fb5c583ac00
  rdi: 0x00007fb5c4535a80  rsi: 0x00007ffee080d180  rbp: 0x00007ffee080d1f0  rsp: 0x00007ffee080d100
   r8: 0x0000000000000000   r9: 0x0000000000c60000  r10: 0x00007fb5c505d800  r11: 0x0012a400000600ff
  r12: 0x0000000000000000  r13: 0x00007fb5c583ac00  r14: 0x0000000000000000  r15: 0x000000010f7a426c
  rip: 0x000000010f42796c  rfl: 0x0000000000010202  cr2: 0x00000000000007d8
Logical CPU:     1
Error Code:      0x00000004 (no mapping for user data read)
Trap Number:     14
Thread 0 instruction stream:
  00 00 48 85 c0 74 1f 0f-b6 4d a8 0f 57 c0 f3 0f  ..H..t...M..W...
  2a c1 f3 0f 5e 05 76 17-14 00 48 8b b8 c0 01 00  *...^.v...H.....
  00 e8 d2 93 fe ff 48 8d-75 90 48 89 df e8 e4 b8  ......H.u.H.....
  01 00 48 8b 83 28 0c 00-00 48 85 c0 0f 84 8a 00  ..H..(...H......
  00 00 48 8b b8 50 0a 00-00 48 85 ff 74 7e 4c 89  ..H..P...H..t~L.
  f8 49 63 87 80 00 00 00-48 8b 84 c3 b8 0d 00 00  .Ic.....H.......
 [83]b8 d8 07 00 00 00 0f-b6 45 a4 0f 57 c0 f3 0f  .........E..W...	<==
  2a c0 74 2c f3 0f 5e 05-14 17 14 00 f3 0f 10 8f  *.t,..^.........
  c4 01 00 00 0f 2e c8 75-02 7b 41 f3 0f 11 87 c4  .......u.{A.....
  01 00 00 48 8b 07 be 01-00 00 00 ff 50 60 eb 2c  ...H........P`.,
  f3 0f 59 05 00 17 14 00-f3 0f 5e 05 e0 16 14 00  ..Y.......^.....
  f3 0f 58 05 f4 16 14 00-f3 0f 2c f0 0f b7 45 96  ..X.......,...E.
Thread 0 last branch register state not available.
Binary Images:
       0x10f3f0000 -        0x10f6fbfff +com.audiofront.eDRUMin (2.0.0 - 16) <303067E6-C3B2-3621-AEA1-82CE4B6E974C> /Applications/eDRUMin.app/Contents/MacOS/eDRUMin
       0x112acb000 -        0x112adafff  libobjc-trampolines.dylib (824) <C1B6BD90-D6AA-388B-B692-D66D512630AA> /usr/lib/libobjc-trampolines.dylib
       0x115c25000 -        0x115c3cfff  com.apple.iokit.IOHIDLib (2.0.0 - 2.0.0) <132C932F-AB40-3E73-8874-2A1E9F617F42> /System/Library/Extensions/IOHIDFamily.kext/Contents/PlugIns/IOHIDLib.plugin/Contents/MacOS/IOHIDLib
       0x117d03000 -        0x117d0afff  com.apple.audio.AppleGFXHDAHALPlugIn (100.1.433 - 100.1.433) <2065ABB8-5CB8-32F8-9A0B-DB8E3A39E897> /System/Library/Extensions/AppleGFXHDA.kext/Contents/PlugIns/AppleGFXHDAHALPlugIn.bundle/Contents/MacOS/AppleGFXHDAHALPlugIn
       0x11beb8000 -        0x11bf53fff  dyld (852.2) <0CC19410-FD43-39AE-A32A-50273F8303A4> /usr/lib/dyld
    0x7fff20269000 -     0x7fff2026afff  libsystem_blocks.dylib (79) <925E3B6D-184D-3E73-97B1-643C4ADB387A> /usr/lib/system/libsystem_blocks.dylib
    0x7fff2026b000 -     0x7fff202a0fff  libxpc.dylib (2038.120.1) <FFFB49D7-2CA6-3E1F-AE4E-5697B19B7D76> /usr/lib/system/libxpc.dylib
    0x7fff202a1000 -     0x7fff202b8fff  libsystem_trace.dylib (1277.120.1) <7E800ECA-DFDB-3737-A3C5-FFDE37E65383> /usr/lib/system/libsystem_trace.dylib
    0x7fff202b9000 -     0x7fff20356fff  libcorecrypto.dylib (1000.140.4) <D211160D-E22F-3440-8054-1F5824519C7F> /usr/lib/system/libcorecrypto.dylib
    0x7fff20357000 -     0x7fff20383fff  libsystem_malloc.dylib (317.140.5) <050E37E1-1458-3F80-BFA3-F1488570169D> /usr/lib/system/libsystem_malloc.dylib
    0x7fff20384000 -     0x7fff203c8fff  libdispatch.dylib (1271.120.2) <8144B0BD-90D2-3EAE-999F-AB0D14082088> /usr/lib/system/libdispatch.dylib
    0x7fff203c9000 -     0x7fff20402fff  libobjc.A.dylib (824) <8C7C49A1-4211-3E4C-BA3D-160D675EEE96> /usr/lib/libobjc.A.dylib
    0x7fff20403000 -     0x7fff20405fff  libsystem_featureflags.dylib (28.60.1) <E5C43AE3-19E7-3DAB-8B5D-D79A4B68B5C0> /usr/lib/system/libsystem_featureflags.dylib
    0x7fff20406000 -     0x7fff2048efff  libsystem_c.dylib (1439.141.1) <3C273899-4CBE-32D5-BB31-7A449743204F> /usr/lib/system/libsystem_c.dylib
    0x7fff2048f000 -     0x7fff204e4fff  libc++.1.dylib (905.6) <FD6DB1CB-B14B-3404-8BEB-B459C2F6C303> /usr/lib/libc++.1.dylib
    0x7fff204e5000 -     0x7fff204fafff  libc++abi.dylib (905.6) <D0CDDF98-1C04-300F-B685-4A4C59C04C42> /usr/lib/libc++abi.dylib
    0x7fff204fb000 -     0x7fff2052afff  libsystem_kernel.dylib (7195.141.6) <78289AAE-61B5-339F-A485-8819BC2388F2> /usr/lib/system/libsystem_kernel.dylib
    0x7fff2052b000 -     0x7fff20536fff  libsystem_pthread.dylib (454.120.2) <1268FF2D-A513-3B51-BA65-AF2FF5789DDB> /usr/lib/system/libsystem_pthread.dylib
    0x7fff20537000 -     0x7fff20572fff  libdyld.dylib (852.2) <3DE0178A-0AEE-3D08-AE19-6C6403F69BA1> /usr/lib/system/libdyld.dylib
    0x7fff20573000 -     0x7fff2057cfff  libsystem_platform.dylib (254.80.2) <EF52D569-09F5-32E1-B1B3-34E2CA55A017> /usr/lib/system/libsystem_platform.dylib
    0x7fff2057d000 -     0x7fff205a8fff  libsystem_info.dylib (542.40.3) <55B39B7F-957B-3D99-A8DF-7CA80D38155D> /usr/lib/system/libsystem_info.dylib
    0x7fff205a9000 -     0x7fff20a46fff  com.apple.CoreFoundation (6.9 - 1778.101) <8CF9D741-ADFF-3D5E-ACDE-DC342701EE0D> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x7fff20a47000 -     0x7fff20c7cfff  com.apple.LaunchServices (1122.44 - 1122.44) <C285E620-3D2F-3AD0-8A3D-BB1FC540FE44> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
    0x7fff20c7d000 -     0x7fff20d51fff  com.apple.gpusw.MetalTools (1.0 - 1) <C41024C5-01E7-3A66-A1F8-D7BC767260D8> /System/Library/PrivateFrameworks/MetalTools.framework/Versions/A/MetalTools
    0x7fff20d52000 -     0x7fff20faefff  libBLAS.dylib (1336.140.1) <170AFA22-1234-3DE9-9D94-52B3BE18E34E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
    0x7fff20faf000 -     0x7fff20ffcfff  com.apple.Lexicon-framework (1.0 - 86.2) <B7047A55-806D-3B32-A2D6-885D824E54A6> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon
    0x7fff20ffd000 -     0x7fff2106bfff  libSparse.dylib (106) <1E68BF64-7432-3509-BC85-5DE95379E901> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparse.dylib
    0x7fff2106c000 -     0x7fff210e9fff  com.apple.SystemConfiguration (1.20 - 1.20) <8FEB39D4-ACD6-39F2-8D1B-A57CACD5628F> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
    0x7fff210ea000 -     0x7fff2111efff  libCRFSuite.dylib (50) <BCDD0ED1-D2F4-3556-B218-4420C7EA47D2> /usr/lib/libCRFSuite.dylib
    0x7fff2111f000 -     0x7fff21357fff  libmecabra.dylib (929.10) <D780814D-2BB2-3D84-820E-12E4C23C590E> /usr/lib/libmecabra.dylib
    0x7fff21358000 -     0x7fff216b6fff  com.apple.Foundation (6.9 - 1778.101) <7B7FB88B-01D3-38CE-8029-837DB094C545> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    0x7fff216b7000 -     0x7fff2179ffff  com.apple.LanguageModeling (1.0 - 247.3) <DBFAE8CF-36B2-30D8-9E82-6C412CD935B4> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
    0x7fff217a0000 -     0x7fff218d6fff  com.apple.CoreDisplay (237.4 - 237.4) <556BADE0-D3B0-309C-9740-7FEFBD052B6B> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
    0x7fff218d7000 -     0x7fff21b47fff  com.apple.audio.AudioToolboxCore (1.0 - 1181.72) <5C3B84EE-B281-34C4-832F-78F00CC63B93> /System/Library/PrivateFrameworks/AudioToolboxCore.framework/Versions/A/AudioToolboxCore
    0x7fff21b48000 -     0x7fff21d2dfff  com.apple.CoreText (677.6.0.2 - 677.6.0.2) <10E1382E-7949-3F4E-8B15-A4BD31A75E91> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
    0x7fff21d2e000 -     0x7fff223bffff  com.apple.audio.CoreAudio (5.0 - 5.0) <5EEA9225-4837-37F3-9105-941A5743169F> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    0x7fff223c0000 -     0x7fff22717fff  com.apple.security (7.0 - 59754.140.13) <A196C85A-DB28-3F5B-A415-5BE44AD81668> /System/Library/Frameworks/Security.framework/Versions/A/Security
    0x7fff22718000 -     0x7fff22977fff  libicucore.A.dylib (66112) <AC994BC1-F9CC-359C-A7B5-F2821EAEF650> /usr/lib/libicucore.A.dylib
    0x7fff22978000 -     0x7fff22981fff  libsystem_darwin.dylib (1439.141.1) <2C81A009-45BB-30D7-A4F7-4B2EEC691617> /usr/lib/system/libsystem_darwin.dylib
    0x7fff22982000 -     0x7fff22c6dfff  com.apple.CoreServices.CarbonCore (1307.3 - 1307.3) <2C65E0D8-A9C7-31D8-A3D3-3AC1A91C80A5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
    0x7fff22c6e000 -     0x7fff22cacfff  com.apple.CoreServicesInternal (476.1.1 - 476.1.1) <3FC6073F-78E4-3D3B-8765-50E50512C5EB> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
    0x7fff22cad000 -     0x7fff22ce7fff  com.apple.CSStore (1122.44 - 1122.44) <C103DAAA-A966-359B-97F0-BA3BB56ECBF1> /System/Library/PrivateFrameworks/CoreServicesStore.framework/Versions/A/CoreServicesStore
    0x7fff22ce8000 -     0x7fff22d96fff  com.apple.framework.IOKit (2.0.2 - 1845.120.6) <720D9AE1-79D6-3E77-8D7A-47F8F6681050> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    0x7fff22d97000 -     0x7fff22da2fff  libsystem_notify.dylib (279.40.4) <2E40EA4A-B124-3010-8379-1B4D7082A08F> /usr/lib/system/libsystem_notify.dylib
    0x7fff22da3000 -     0x7fff22df0fff  libsandbox.1.dylib (1441.141.4) <C291C059-F7E4-3C20-BCBF-60F7011F0718> /usr/lib/libsandbox.1.dylib
    0x7fff22df1000 -     0x7fff23b3cfff  com.apple.AppKit (6.9 - 2022.60.128) <02EC69A0-D634-341B-BE3D-840F496F5814> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x7fff23b3d000 -     0x7fff23d8bfff  com.apple.UIFoundation (1.0 - 728.9) <C2E04F0F-AEAA-3B77-9BBA-1CF628341A56> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
    0x7fff23d8c000 -     0x7fff23d9efff  com.apple.UniformTypeIdentifiers (637 - 637) <8FFD3B69-0840-34D6-83AD-7D521B1A2339> /System/Library/Frameworks/UniformTypeIdentifiers.framework/Versions/A/UniformTypeIdentifiers
    0x7fff23d9f000 -     0x7fff23f29fff  com.apple.desktopservices (1.21 - 1346.6.1) <F2C97567-5B56-3840-A384-2131E362083B> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
    0x7fff24209000 -     0x7fff2488ffff  libnetwork.dylib (2288.140.7) <42825FCA-35A1-352F-AE68-19D8F695604B> /usr/lib/libnetwork.dylib
    0x7fff24890000 -     0x7fff24d2efff  com.apple.CFNetwork (1240.0.4 - 1240.0.4) <E4BF9BFF-798B-33FF-B37D-6D8175CA708A> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
    0x7fff24d2f000 -     0x7fff24d3dfff  libsystem_networkextension.dylib (1295.140.3) <83AA4425-2F1D-36EC-B77B-8D4F03CDDB68> /usr/lib/system/libsystem_networkextension.dylib
    0x7fff24d3e000 -     0x7fff24d3efff  libenergytrace.dylib (22.100.1) <9E877E0A-5261-3F75-91A0-521423499AD0> /usr/lib/libenergytrace.dylib
    0x7fff24d3f000 -     0x7fff24d9bfff  libMobileGestalt.dylib (978.140.1) <D1FF79C3-4B2F-32FB-BF25-9F0B9E160692> /usr/lib/libMobileGestalt.dylib
    0x7fff24d9c000 -     0x7fff24db2fff  libsystem_asl.dylib (385) <8D324D65-EE16-3A1A-BD39-ACB1B3050D1F> /usr/lib/system/libsystem_asl.dylib
    0x7fff24db3000 -     0x7fff24dcbfff  com.apple.TCC (1.0 - 1) <18F48712-FFF0-3B30-B2C4-8A93AEF86A34> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
    0x7fff24dcc000 -     0x7fff25131fff  com.apple.SkyLight (1.600.0 - 588.7) <5F88F814-A3DF-3446-8B35-F0CDD8C1B302> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
    0x7fff25132000 -     0x7fff257bbfff  com.apple.CoreGraphics (2.0 - 1463.17.3) <5EDF86BC-FFDE-3906-9674-142C113B34EF> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
    0x7fff257bc000 -     0x7fff258b2fff  com.apple.ColorSync (4.13.0 - 3473.4.3) <102C423C-E05F-317B-83AE-A2A6B77D653B> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
    0x7fff258b3000 -     0x7fff2590efff  com.apple.HIServices (1.22 - 716) <B2D34F3F-0CEB-35F1-9B32-E0806CF3FC91> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
    0x7fff25cb5000 -     0x7fff260d4fff  com.apple.CoreData (120 - 1048) <33DE1B26-D4C6-3939-B12E-88897660BB38> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
    0x7fff260d5000 -     0x7fff260eafff  com.apple.ProtocolBuffer (1 - 285.24.10.20.1) <AEDEFF64-CA8A-365C-900F-3107383F91D9> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
    0x7fff260eb000 -     0x7fff2629efff  libsqlite3.dylib (321.3) <E7377C46-DA4F-3486-B935-0A35C3637215> /usr/lib/libsqlite3.dylib
    0x7fff2629f000 -     0x7fff2631bfff  com.apple.Accounts (113 - 113) <2AD45648-B327-313A-ACF2-846FB345A96E> /System/Library/Frameworks/Accounts.framework/Versions/A/Accounts
    0x7fff2631c000 -     0x7fff26333fff  com.apple.commonutilities (8.0 - 900) <98B456F4-8F4F-387B-B3BB-D3919295AE1D> /System/Library/PrivateFrameworks/CommonUtilities.framework/Versions/A/CommonUtilities
    0x7fff26334000 -     0x7fff263b3fff  com.apple.BaseBoard (526 - 526) <F9D85C3A-D0D6-351B-A6EE-5416CB90179D> /System/Library/PrivateFrameworks/BaseBoard.framework/Versions/A/BaseBoard
    0x7fff263b4000 -     0x7fff263fcfff  com.apple.RunningBoardServices (1.0 - 505.100.9) <2ED406CD-2253-33F0-B16A-694DB447CADC> /System/Library/PrivateFrameworks/RunningBoardServices.framework/Versions/A/RunningBoardServices
    0x7fff263fd000 -     0x7fff26471fff  com.apple.AE (918.6 - 918.6) <C5130BB4-18E7-3804-A9D9-915D318426A5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
    0x7fff26472000 -     0x7fff26478fff  libdns_services.dylib (1310.140.1) <22BE5030-2F48-3ED6-9DF8-9D102CEF33FF> /usr/lib/libdns_services.dylib
    0x7fff26479000 -     0x7fff26480fff  libsystem_symptoms.dylib (1431.140.1) <1B4D8837-C951-3B69-B079-85D477749E8B> /usr/lib/system/libsystem_symptoms.dylib
    0x7fff26481000 -     0x7fff2660cfff  com.apple.Network (1.0 - 1) <2155E1AA-2067-36CF-979E-2F96062D5CFE> /System/Library/Frameworks/Network.framework/Versions/A/Network
    0x7fff2660d000 -     0x7fff2663cfff  com.apple.analyticsd (1.0 - 1) <0DF60ECD-742C-39D1-964A-48EC3DEA6319> /System/Library/PrivateFrameworks/CoreAnalytics.framework/Versions/A/CoreAnalytics
    0x7fff2663d000 -     0x7fff2663ffff  libDiagnosticMessagesClient.dylib (112) <A7EC7265-E13C-3C98-81EE-3EFB5CC65AB0> /usr/lib/libDiagnosticMessagesClient.dylib
    0x7fff26640000 -     0x7fff2668cfff  com.apple.spotlight.metadata.utilities (1.0 - 2150.26) <F709AE5E-AF80-3C9B-A3D3-B779164FBA95> /System/Library/PrivateFrameworks/MetadataUtilities.framework/Versions/A/MetadataUtilities
    0x7fff2668d000 -     0x7fff26727fff  com.apple.Metadata (10.7.0 - 2150.26) <D7CE41CA-DDE7-32BE-926C-0DC3048C5E11> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
    0x7fff26728000 -     0x7fff2672efff  com.apple.DiskArbitration (2.7 - 2.7) <8DF059B4-BE32-3171-8CC4-C5FA189FA718> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
    0x7fff2672f000 -     0x7fff26d96fff  com.apple.vImage (8.1 - 544.4) <E62F9E4F-9A1D-3004-B7F4-6F83F71144C2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
    0x7fff26d97000 -     0x7fff27074fff  com.apple.QuartzCore (1.11 - 927.24) <88794856-F1F1-3D23-BDDB-0AE28A1D6D6E> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x7fff27075000 -     0x7fff270b6fff  libFontRegistry.dylib (309) <300F2208-7274-38F8-B88D-9237BA6B397E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
    0x7fff270b7000 -     0x7fff271f7fff  com.apple.coreui (2.1 - 692.1) <BC5D8EAA-7CE8-35F3-8EAD-075B18D9606C> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
    0x7fff271f8000 -     0x7fff272e3fff  com.apple.ViewBridge (553.1 - 553.1) <DF83EA6E-4DA9-3322-BE86-0B3207167451> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
    0x7fff272e4000 -     0x7fff272effff  com.apple.PerformanceAnalysis (1.278.3 - 278.3) <6AF20F05-FF15-3174-A504-1AC16BA14729> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
    0x7fff272f0000 -     0x7fff272fffff  com.apple.OpenDirectory (11.6 - 230.40.1) <84B2D11F-E6C4-3C29-9A9A-939DB906E2F5> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
    0x7fff27300000 -     0x7fff2731ffff  com.apple.CFOpenDirectory (11.6 - 230.40.1) <6BE3204F-2F86-34A7-AD79-4C88320F446F> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
    0x7fff27320000 -     0x7fff2732cfff  com.apple.CoreServices.FSEvents (1290.120.5 - 1290.120.5) <DC473A17-310F-3C16-B545-F75CE3F6D39D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
    0x7fff2732d000 -     0x7fff27351fff  com.apple.coreservices.SharedFileList (144 - 144) <A13B58B8-6D7A-3F1B-AFB5-E41E0A6B4B81> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
    0x7fff27352000 -     0x7fff27354fff  libapp_launch_measurement.dylib (14.1) <511EC2A9-6059-3A7D-9D2A-741189922D02> /usr/lib/libapp_launch_measurement.dylib
    0x7fff27355000 -     0x7fff2739cfff  com.apple.CoreAutoLayout (1.0 - 21.10.1) <18113C8E-B54E-3DD3-A1AD-2A5FD949CE66> /System/Library/PrivateFrameworks/CoreAutoLayout.framework/Versions/A/CoreAutoLayout
    0x7fff2739d000 -     0x7fff2747ffff  libxml2.2.dylib (34.10) <DD2093F0-F9B7-3F30-B46D-B028CE15E2B1> /usr/lib/libxml2.2.dylib
    0x7fff27480000 -     0x7fff274cdfff  com.apple.CoreVideo (1.8 - 414.7) <EE991A40-DE38-3B13-891E-A51987D5CD70> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
    0x7fff274ce000 -     0x7fff274d0fff  com.apple.loginsupport (1.0 - 1) <4C358D8E-4BB8-3DD8-8A72-11BD80607BDE> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
    0x7fff274f9000 -     0x7fff27514fff  com.apple.UserManagement (1.0 - 1) <FB298359-31F5-3DDD-B928-604C4B1ED1F3> /System/Library/PrivateFrameworks/UserManagement.framework/Versions/A/UserManagement
    0x7fff28488000 -     0x7fff28498fff  libsystem_containermanager.dylib (318.100.4) <1139CD47-9CBA-356F-8694-1D00EB9F0C8F> /usr/lib/system/libsystem_containermanager.dylib
    0x7fff28499000 -     0x7fff284aafff  com.apple.IOSurface (290.8.1 - 290.8.1) <8B251196-DA38-38BF-8A91-45AC2B06014C> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
    0x7fff284ab000 -     0x7fff284b4fff  com.apple.IOAccelerator (442.9 - 442.9) <F2C3DC87-49D7-3A67-8E6D-12D75D98EFDD> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
    0x7fff284b5000 -     0x7fff285d8fff  com.apple.Metal (244.303 - 244.303) <71B6039E-232E-3AD2-881F-DF8E73C75B99> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
    0x7fff285d9000 -     0x7fff285f5fff  com.apple.audio.caulk (1.0 - 70) <F6A09FF3-1DC7-302C-86E3-B2DD9B7130A9> /System/Library/PrivateFrameworks/caulk.framework/Versions/A/caulk
    0x7fff285f6000 -     0x7fff286e0fff  com.apple.CoreMedia (1.0 - 2780.10) <6A003180-F8AA-3DFA-B095-61D8E859FE3F> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
    0x7fff286e1000 -     0x7fff2883dfff  libFontParser.dylib (305.6.0.4) <C3E552F6-72AD-3F3A-B217-E44A5C565240> /System/Library/PrivateFrameworks/FontServices.framework/libFontParser.dylib
    0x7fff2883e000 -     0x7fff28b39fff  com.apple.HIToolbox (2.1.1 - 1062) <DEF01A0C-8B9D-359E-9FE7-B15D551888DC> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
    0x7fff28b3a000 -     0x7fff28b4dfff  com.apple.framework.DFRFoundation (1.0 - 267) <EBFDDB28-7661-3B50-BC15-736C5DF05AB3> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
    0x7fff28b4e000 -     0x7fff28b51fff  com.apple.dt.XCTTargetBootstrap (1.0 - 18119.1) <DD9E09C3-B658-3BD2-8229-E3E3C5D85552> /System/Library/PrivateFrameworks/XCTTargetBootstrap.framework/Versions/A/XCTTargetBootstrap
    0x7fff28b52000 -     0x7fff28b7bfff  com.apple.CoreSVG (1.0 - 149) <C4DC952A-9373-33E5-8A98-F008986B0420> /System/Library/PrivateFrameworks/CoreSVG.framework/Versions/A/CoreSVG
    0x7fff28b7c000 -     0x7fff28db8fff  com.apple.ImageIO (3.3.0 - 2130.7.3) <28C6A501-2548-3187-A13B-9F314280BBB8> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
    0x7fff28db9000 -     0x7fff29134fff  com.apple.CoreImage (16.3.0 - 1140.2) <3ED3F244-632C-383D-89B0-50F2E0FDBA40> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
    0x7fff29135000 -     0x7fff2919bfff  com.apple.MetalPerformanceShaders.MPSCore (1.0 - 1) <C12F8828-6D1E-3820-BBF7-80EEA978AE9C> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSCore.framework/Versions/A/MPSCore
    0x7fff2919c000 -     0x7fff2919ffff  libsystem_configuration.dylib (1109.140.1) <02F3A5C9-6289-3012-8F5F-F1DB669ADB79> /usr/lib/system/libsystem_configuration.dylib
    0x7fff291a0000 -     0x7fff291a4fff  libsystem_sandbox.dylib (1441.141.4) <5471601B-5072-3E97-8926-804FF08DC4C0> /usr/lib/system/libsystem_sandbox.dylib
    0x7fff291a5000 -     0x7fff291a6fff  com.apple.AggregateDictionary (1.0 - 1) <B25A1764-0BBC-388B-8FB4-A8FBB8F51C10> /System/Library/PrivateFrameworks/AggregateDictionary.framework/Versions/A/AggregateDictionary
    0x7fff291a7000 -     0x7fff291aafff  com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <4A803F86-CA61-3508-864A-302F032ADA70> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
    0x7fff291ab000 -     0x7fff291acfff  liblangid.dylib (136) <F4019132-A63D-3A38-A8DB-974C6F1311ED> /usr/lib/liblangid.dylib
    0x7fff291ad000 -     0x7fff29251fff  com.apple.CoreNLP (1.0 - 245.2) <203C6AB9-5B07-3370-A056-DA1F2C8A8419> /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP
    0x7fff29252000 -     0x7fff29258fff  com.apple.LinguisticData (1.0 - 399) <AB85B59F-3047-37EC-AB9E-835D87BACF73> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData
    0x7fff29259000 -     0x7fff29901fff  libBNNS.dylib (288.100.5) <4BB7A1B7-D1F2-3DC3-BFC7-D57CBD892719> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
    0x7fff29902000 -     0x7fff29ad4fff  libvDSP.dylib (760.100.3) <DA809F3E-9391-3BE0-98C6-061CCACA809A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
    0x7fff29ad5000 -     0x7fff29ae6fff  com.apple.CoreEmoji (1.0 - 128.4) <8DB42230-A624-3C13-80F8-EC2CE89C0699> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
    0x7fff29ae7000 -     0x7fff29af1fff  com.apple.IOMobileFramebuffer (343.0.0 - 343.0.0) <195E20E7-33BD-3935-92ED-AA354180B7FA> /System/Library/PrivateFrameworks/IOMobileFramebuffer.framework/Versions/A/IOMobileFramebuffer
    0x7fff29af2000 -     0x7fff29bc4fff  com.apple.framework.CoreWLAN (16.0 - 1657) <0A58C97E-2ACD-3223-8585-FDA5DA4C38C5> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
    0x7fff29bc5000 -     0x7fff29dc6fff  com.apple.CoreUtils (6.6 - 660.37) <0B1ED18A-B228-3840-A0F2-23AC2C37A6CA> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
    0x7fff29dc7000 -     0x7fff29de9fff  com.apple.MobileKeyBag (2.0 - 1.0) <19D8140C-CC92-35E8-AF78-B335567A7C24> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
    0x7fff29dea000 -     0x7fff29dfafff  com.apple.AssertionServices (1.0 - 505.100.9) <850AE031-A3B3-30C0-81A1-71FBCE620BC1> /System/Library/PrivateFrameworks/AssertionServices.framework/Versions/A/AssertionServices
    0x7fff29dfb000 -     0x7fff29e86fff  com.apple.securityfoundation (6.0 - 55240.40.4) <A7D05091-B54C-317A-81FE-4B174C968C5A> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
    0x7fff29e87000 -     0x7fff29e90fff  com.apple.coreservices.BackgroundTaskManagement (1.0 - 104) <98B365F9-8E0C-32C7-AC5A-FFB9A4A0B30A> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement
    0x7fff29e91000 -     0x7fff29e95fff  com.apple.xpc.ServiceManagement (1.0 - 1) <7D081389-0032-3521-A3D9-84B4667817FB> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
    0x7fff29e96000 -     0x7fff29e98fff  libquarantine.dylib (119.40.2) <3244B57B-9FDF-373E-9F96-A7BAD7534F23> /usr/lib/system/libquarantine.dylib
    0x7fff29e99000 -     0x7fff29ea4fff  libCheckFix.dylib (31) <AAB549BA-1738-33FD-BBC4-C34B5070C309> /usr/lib/libCheckFix.dylib
    0x7fff29ea5000 -     0x7fff29ebcfff  libcoretls.dylib (169.100.1) <FC2811AD-9D76-3403-B760-32A101D07638> /usr/lib/libcoretls.dylib
    0x7fff29ebd000 -     0x7fff29ecdfff  libbsm.0.dylib (68.40.1) <61577B7F-2C06-365C-9039-E00B0B5258D0> /usr/lib/libbsm.0.dylib
    0x7fff29ece000 -     0x7fff29f17fff  libmecab.dylib (929.10) <D60C5095-3A5F-3284-9699-08C76DA29CBD> /usr/lib/libmecab.dylib
    0x7fff29f18000 -     0x7fff29f1dfff  libgermantok.dylib (24) <6F2B01E8-6077-3B72-91F3-AB6D0FCB15D6> /usr/lib/libgermantok.dylib
    0x7fff29f1e000 -     0x7fff29f33fff  libLinearAlgebra.dylib (1336.140.1) <A450756D-D3AC-342D-A802-ED6C554A494A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
    0x7fff29f34000 -     0x7fff2a152fff  com.apple.MetalPerformanceShaders.MPSNeuralNetwork (1.0 - 1) <8AAFA6C5-1FBD-359A-8774-F1D1FBFCCFFE> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSNeuralNetwork.framework/Versions/A/MPSNeuralNetwork
    0x7fff2a153000 -     0x7fff2a1a2fff  com.apple.MetalPerformanceShaders.MPSRayIntersector (1.0 - 1) <0C854684-1D62-35D1-83C1-9066DB158189> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSRayIntersector.framework/Versions/A/MPSRayIntersector
    0x7fff2a1a3000 -     0x7fff2a304fff  com.apple.MLCompute (1.0 - 1) <9255AB44-3AB5-3F3F-8FA2-77FEA1C7C221> /System/Library/Frameworks/MLCompute.framework/Versions/A/MLCompute
    0x7fff2a305000 -     0x7fff2a33bfff  com.apple.MetalPerformanceShaders.MPSMatrix (1.0 - 1) <B7361691-334A-3A33-98E1-A9A623E5D26A> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSMatrix.framework/Versions/A/MPSMatrix
    0x7fff2a33c000 -     0x7fff2a392fff  com.apple.MetalPerformanceShaders.MPSNDArray (1.0 - 1) <706E8171-48B3-33A3-B55B-35B5F86F3043> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSNDArray.framework/Versions/A/MPSNDArray
    0x7fff2a393000 -     0x7fff2a423fff  com.apple.MetalPerformanceShaders.MPSImage (1.0 - 1) <3999E177-7A40-358A-BE89-1F20ADF13740> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSImage.framework/Versions/A/MPSImage
    0x7fff2a424000 -     0x7fff2a433fff  com.apple.AppleFSCompression (125 - 1.0) <F7163A3A-C4F0-3169-9501-B9AAB8CAE9CD> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
    0x7fff2a434000 -     0x7fff2a440fff  libbz2.1.0.dylib (44) <ECD22F5B-FD6C-39A5-884B-418C6B896263> /usr/lib/libbz2.1.0.dylib
    0x7fff2a441000 -     0x7fff2a445fff  libsystem_coreservices.dylib (127.1) <619CCB6D-226C-35BD-98FB-04A18FD54792> /usr/lib/system/libsystem_coreservices.dylib
    0x7fff2a446000 -     0x7fff2a473fff  com.apple.CoreServices.OSServices (1122.44 - 1122.44) <C547575F-985F-31B8-A61C-79D3A673B8D9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
    0x7fff2a474000 -     0x7fff2a5a3fff  com.apple.AuthKit (1.0 - 1) <C72D7981-A3B6-3883-A14F-43485DF54FC4> /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/AuthKit
    0x7fff2a642000 -     0x7fff2a654fff  libz.1.dylib (76) <F805C1CB-1B80-33D0-994C-1D522D347A68> /usr/lib/libz.1.dylib
    0x7fff2a655000 -     0x7fff2a69cfff  libsystem_m.dylib (3186.100.3) <D61B56FE-649B-34A0-8446-25685B2BBBF2> /usr/lib/system/libsystem_m.dylib
    0x7fff2a69d000 -     0x7fff2a69dfff  libcharset.1.dylib (59) <363A6C40-7446-3A72-B5EA-4731843CFE2F> /usr/lib/libcharset.1.dylib
    0x7fff2a69e000 -     0x7fff2a6a3fff  libmacho.dylib (980) <A4F4D532-7824-3E4E-8FB6-45617415E7DD> /usr/lib/system/libmacho.dylib
    0x7fff2a6a4000 -     0x7fff2a6bffff  libkxld.dylib (7195.141.6) <1121F83B-5D42-368B-B440-100418CD4B23> /usr/lib/system/libkxld.dylib
    0x7fff2a6c0000 -     0x7fff2a6cbfff  libcommonCrypto.dylib (60178.120.3) <CF1E0E70-9F6C-3FAF-82B2-D55F7C9EBB03> /usr/lib/system/libcommonCrypto.dylib
    0x7fff2a6cc000 -     0x7fff2a6d6fff  libunwind.dylib (201) <4602E909-C71A-3006-8140-BE616DA241EE> /usr/lib/system/libunwind.dylib
    0x7fff2a6d7000 -     0x7fff2a6defff  liboah.dylib (203.58) <F72C2D50-7279-3497-8A59-56908F9661F3> /usr/lib/liboah.dylib
    0x7fff2a6df000 -     0x7fff2a6e9fff  libcopyfile.dylib (173.40.2) <B0F35A80-D5E3-33DD-A47D-ACBFE1300523> /usr/lib/system/libcopyfile.dylib
    0x7fff2a6ea000 -     0x7fff2a6f1fff  libcompiler_rt.dylib (102.2) <1C049207-1719-39AC-A2A9-6E5BE28AA138> /usr/lib/system/libcompiler_rt.dylib
    0x7fff2a6f2000 -     0x7fff2a6f4fff  libsystem_collections.dylib (1439.141.1) <F2D775D9-AAEF-371F-AA54-CFB882B9B430> /usr/lib/system/libsystem_collections.dylib
    0x7fff2a6f5000 -     0x7fff2a6f7fff  libsystem_secinit.dylib (87.60.1) <EB4516ED-1F8B-3E8A-8C4B-B209A33DCCEF> /usr/lib/system/libsystem_secinit.dylib
    0x7fff2a6f8000 -     0x7fff2a6fafff  libremovefile.dylib (49.120.1) <1AEE3D84-32F9-35FB-8036-B178C9E27D20> /usr/lib/system/libremovefile.dylib
    0x7fff2a6fb000 -     0x7fff2a6fbfff  libkeymgr.dylib (31) <698AF6EE-08BB-36CF-B7AD-9EC16E36FA0B> /usr/lib/system/libkeymgr.dylib
    0x7fff2a6fc000 -     0x7fff2a703fff  libsystem_dnssd.dylib (1310.140.1) <0685BDB0-9A98-3ADD-B95A-11F221FD80D7> /usr/lib/system/libsystem_dnssd.dylib
    0x7fff2a704000 -     0x7fff2a709fff  libcache.dylib (83) <B51FAB34-AA9C-38C5-95F1-E5E54B21EA67> /usr/lib/system/libcache.dylib
    0x7fff2a70a000 -     0x7fff2a70bfff  libSystem.B.dylib (1292.120.1) <DBD0A184-CD98-3225-8E9B-D5BFE0D30562> /usr/lib/libSystem.B.dylib
    0x7fff2a70c000 -     0x7fff2a70ffff  libfakelink.dylib (3) <BE0E6C60-675A-3739-A47A-67C650B1F790> /usr/lib/libfakelink.dylib
    0x7fff2a710000 -     0x7fff2a710fff  com.apple.SoftLinking (1.0 - 1) <9E4B6591-74E3-3B36-91C4-851FAA567DAA> /System/Library/PrivateFrameworks/SoftLinking.framework/Versions/A/SoftLinking
    0x7fff2a711000 -     0x7fff2a748fff  libpcap.A.dylib (98.100.3) <6DD23455-C0CA-313E-89B5-A45F8CD71C20> /usr/lib/libpcap.A.dylib
    0x7fff2a749000 -     0x7fff2a839fff  libiconv.2.dylib (59) <90F749E2-9D2D-3323-A018-31A1F95221A1> /usr/lib/libiconv.2.dylib
    0x7fff2a83a000 -     0x7fff2a84bfff  libcmph.dylib (8) <17871D7D-49C2-3343-AC30-C40E3AD5B2B6> /usr/lib/libcmph.dylib
    0x7fff2a84c000 -     0x7fff2a8bdfff  libarchive.2.dylib (83.100.2) <5AF9560E-5683-33A5-8D60-A469193B94E3> /usr/lib/libarchive.2.dylib
    0x7fff2a8be000 -     0x7fff2a925fff  com.apple.SearchKit (1.4.1 - 1.4.1) <A45AE5BD-9242-351E-B621-3EB50F66AB30> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
    0x7fff2a926000 -     0x7fff2a927fff  libThaiTokenizer.dylib (3) <7B40AC51-B945-3AF0-B349-5818050D37FB> /usr/lib/libThaiTokenizer.dylib
    0x7fff2a928000 -     0x7fff2a94afff  com.apple.applesauce (1.0 - 16.28) <7D011403-38CD-37DA-B2C2-00D2D2273422> /System/Library/PrivateFrameworks/AppleSauce.framework/Versions/A/AppleSauce
    0x7fff2a94b000 -     0x7fff2a962fff  libapple_nghttp2.dylib (1.41) <E3FCBDB9-6671-3368-B371-B9CAC9BB1B45> /usr/lib/libapple_nghttp2.dylib
    0x7fff2a963000 -     0x7fff2a979fff  libSparseBLAS.dylib (1336.140.1) <78762464-084C-3743-BC56-A2AF5D010909> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
    0x7fff2a97a000 -     0x7fff2a97bfff  com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <BD2B6B2B-E116-3B97-A25F-71B4AC7B2BA6> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
    0x7fff2a97c000 -     0x7fff2a980fff  libpam.2.dylib (28.40.1) <E73D1903-42B9-3FF9-AE5D-482672F015AC> /usr/lib/libpam.2.dylib
    0x7fff2a981000 -     0x7fff2a9a0fff  libcompression.dylib (96.120.1) <CFE780B4-AFB0-327C-BB68-A5565AA7C630> /usr/lib/libcompression.dylib
    0x7fff2a9a1000 -     0x7fff2a9a6fff  libQuadrature.dylib (7) <9668C241-61D5-3AE9-9856-708ACDC27F12> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
    0x7fff2a9a7000 -     0x7fff2ad44fff  libLAPACK.dylib (1336.140.1) <8B968A9A-8263-3639-A740-636387467C03> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
    0x7fff2ad45000 -     0x7fff2ad94fff  com.apple.DictionaryServices (1.2 - 341) <617030DF-769F-3CE0-869F-7F5B9B5A3784> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
    0x7fff2ad95000 -     0x7fff2adadfff  liblzma.5.dylib (16) <6DE3F2AA-7140-3F6D-AD12-0DBA19BBBD54> /usr/lib/liblzma.5.dylib
    0x7fff2adae000 -     0x7fff2adaffff  libcoretls_cfhelpers.dylib (169.100.1) <0CF72D7A-0A39-3683-82ED-29A09761D6FF> /usr/lib/libcoretls_cfhelpers.dylib
    0x7fff2adb0000 -     0x7fff2aeabfff  com.apple.APFS (1677.141.2 - 1677.141.2) <F42A21D0-F8CE-3DDA-ACE6-C0AC9EE2FA6C> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
    0x7fff2aeac000 -     0x7fff2aeb9fff  libxar.1.dylib (452) <0B0B68CC-D627-3BDC-AE01-007C6AD8E97B> /usr/lib/libxar.1.dylib
    0x7fff2aeba000 -     0x7fff2aebdfff  libutil.dylib (58.40.2) <0EA3237C-B6E6-351B-AE27-8975D88602D6> /usr/lib/libutil.dylib
    0x7fff2aebe000 -     0x7fff2aee6fff  libxslt.1.dylib (17.6) <300C3D2D-19B1-3D8E-B212-1D2EB6C8B80A> /usr/lib/libxslt.1.dylib
    0x7fff2aee7000 -     0x7fff2aef1fff  libChineseTokenizer.dylib (37.1) <B4314553-EF8B-3CD4-A7D8-76CD7FC7142D> /usr/lib/libChineseTokenizer.dylib
    0x7fff2aef2000 -     0x7fff2afaffff  libvMisc.dylib (760.100.3) <B8F30684-94D1-3A53-80BF-C78F424594AD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
    0x7fff2afb0000 -     0x7fff2b047fff  libate.dylib (3.0.6) <FA881406-28F3-33BD-B75D-40389CE2ADD1> /usr/lib/libate.dylib
    0x7fff2b048000 -     0x7fff2b04ffff  libIOReport.dylib (64.100.1) <4D638FAC-2FD8-359C-8159-1ED37CBB5704> /usr/lib/libIOReport.dylib
    0x7fff2b151000 -     0x7fff2b158fff  libMatch.1.dylib (38) <85F66EF8-FC5E-385C-AF8F-79532C2AC988> /usr/lib/libMatch.1.dylib
    0x7fff2b159000 -     0x7fff2b1e4fff  libCoreStorage.dylib (554.140.2) <249F3E03-6C96-3E20-999A-BBFE36AADECA> /usr/lib/libCoreStorage.dylib
    0x7fff2b1e5000 -     0x7fff2b238fff  com.apple.AppleVAFramework (6.1.3 - 6.1.3) <2CDA1194-F435-3B9C-94A2-220E26E40DE6> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
    0x7fff2b239000 -     0x7fff2b252fff  libexpat.1.dylib (26.141.1) <84DC54E5-9E75-3F64-9D7F-3CA641674ED8> /usr/lib/libexpat.1.dylib
    0x7fff2b253000 -     0x7fff2b25cfff  libheimdal-asn1.dylib (597.140.2) <8D7B3A0D-A699-3947-9E8C-EEA4B4AD6408> /usr/lib/libheimdal-asn1.dylib
    0x7fff2b25d000 -     0x7fff2b271fff  com.apple.IconFoundation (479.4 - 479.4) <6ED33568-2A1D-3918-9D32-D1E102002E48> /System/Library/PrivateFrameworks/IconFoundation.framework/Versions/A/IconFoundation
    0x7fff2b272000 -     0x7fff2b2defff  com.apple.IconServices (479.4 - 479.4) <D94D5AF3-6EF6-30D8-A7F8-58A1A3E5641B> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
    0x7fff2b2df000 -     0x7fff2b37dfff  com.apple.MediaExperience (1.0 - 1) <245932F7-E76A-37A7-A033-7BB62F8ED190> /System/Library/PrivateFrameworks/MediaExperience.framework/Versions/A/MediaExperience
    0x7fff2b37e000 -     0x7fff2b3a6fff  com.apple.persistentconnection (1.0 - 1.0) <90FBA2DD-E91A-3A9F-80C5-8F94950136A4> /System/Library/PrivateFrameworks/PersistentConnection.framework/Versions/A/PersistentConnection
    0x7fff2b3a7000 -     0x7fff2b3b5fff  com.apple.GraphVisualizer (1.0 - 100.1) <9538C368-5703-367B-ADAE-20EC5C3C5C41> /System/Library/PrivateFrameworks/GraphVisualizer.framework/Versions/A/GraphVisualizer
    0x7fff2b3b6000 -     0x7fff2b7d1fff  com.apple.vision.FaceCore (4.3.2 - 4.3.2) <86110F21-96FE-325C-8D55-9385690C2386> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
    0x7fff2b7d2000 -     0x7fff2b819fff  com.apple.OTSVG (1.0 - 677.6.0.2) <34AD6D57-71B8-3859-94AF-DB856D8FD6BA> /System/Library/PrivateFrameworks/OTSVG.framework/Versions/A/OTSVG
    0x7fff2b81a000 -     0x7fff2b820fff  com.apple.xpc.AppServerSupport (1.0 - 2038.120.1) <AD03039F-3D12-31FE-A497-EC4A87097683> /System/Library/PrivateFrameworks/AppServerSupport.framework/Versions/A/AppServerSupport
    0x7fff2b821000 -     0x7fff2b833fff  libhvf.dylib (1.0 - $[CURRENT_PROJECT_VERSION]) <B4F0CDA6-0332-3AB9-A0FB-8CD6EE316D30> /System/Library/PrivateFrameworks/FontServices.framework/libhvf.dylib
    0x7fff2b834000 -     0x7fff2b836fff  libspindump.dylib (295.2) <8DE7E414-DCEC-30B8-87DC-511D362D49F3> /usr/lib/libspindump.dylib
    0x7fff2b837000 -     0x7fff2b8f7fff  com.apple.Heimdal (4.0 - 2.0) <30D71BC9-C18F-35C7-B7E1-88E645D4D329> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
    0x7fff2b8f8000 -     0x7fff2b912fff  com.apple.login (3.0 - 3.0) <0690C64C-DE8C-3AA2-A4A5-BE3EFC3BDC62> /System/Library/PrivateFrameworks/login.framework/Versions/A/login
    0x7fff2ba97000 -     0x7fff2bad3fff  com.apple.bom (14.0 - 235) <E428566D-DFA2-33AC-AF3B-C68530D52522> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
    0x7fff2bad4000 -     0x7fff2bb1dfff  com.apple.AppleJPEG (1.0 - 1) <15DCB33B-EB52-38A2-B02F-EC235DC85B52> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
    0x7fff2bb1e000 -     0x7fff2bbfdfff  libJP2.dylib (2130.7.3) <20747AB5-CFA0-3C7A-BE41-BF4B54FD2038> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
    0x7fff2bbfe000 -     0x7fff2bc01fff  com.apple.WatchdogClient.framework (1.0 - 98.120.2) <0A097C25-405B-38CD-B6E2-57F51AD77AF0> /System/Library/PrivateFrameworks/WatchdogClient.framework/Versions/A/WatchdogClient
    0x7fff2bc02000 -     0x7fff2bc38fff  com.apple.MultitouchSupport.framework (4440.3 - 4440.3) <0DF955E2-E57C-3C1B-96BD-5B81DAD43BC7> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
    0x7fff2bc39000 -     0x7fff2bd97fff  com.apple.VideoToolbox (1.0 - 2780.10) <4FF9A4C0-FFB4-3F68-9A84-949B4DB0DB7A> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
    0x7fff2bd98000 -     0x7fff2bdcbfff  libAudioToolboxUtility.dylib (1181.72) <9D9EA545-924D-342A-BF27-C19887850F05> /usr/lib/libAudioToolboxUtility.dylib
    0x7fff2bdcc000 -     0x7fff2bdecfff  libPng.dylib (2130.7.3) <29756FE6-34E9-3760-9B70-9FF6648BE7CC> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
    0x7fff2bded000 -     0x7fff2be4cfff  libTIFF.dylib (2130.7.3) <692B9470-8F28-3C98-9C6A-DAE79FE0136F> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
    0x7fff2be4d000 -     0x7fff2be69fff  com.apple.IOPresentment (58 - 37) <A86E6181-E216-3691-A7FF-0264A927C8CC> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
    0x7fff2be6a000 -     0x7fff2be71fff  com.apple.GPUWrangler (6.3.5 - 6.3.5) <CC101DAE-349B-3C72-9554-6F569364841E> /System/Library/PrivateFrameworks/GPUWrangler.framework/Versions/A/GPUWrangler
    0x7fff2be72000 -     0x7fff2be75fff  libRadiance.dylib (2130.7.3) <1A759A2B-28E8-32C4-940D-BE0239558098> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
    0x7fff2be76000 -     0x7fff2be7bfff  com.apple.DSExternalDisplay (3.1 - 380) <3FD5886F-5EDD-313D-9783-FF899E5F2650> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
    0x7fff2be7c000 -     0x7fff2bea0fff  libJPEG.dylib (2130.7.3) <C0903C97-523A-3822-ABE4-D1047D6785DC> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
    0x7fff2bea1000 -     0x7fff2bed0fff  com.apple.ATSUI (1.0 - 1) <F9BEFF92-E409-35B6-89CB-0F221D804D3C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATSUI.framework/Versions/A/ATSUI
    0x7fff2bed1000 -     0x7fff2bed5fff  libGIF.dylib (2130.7.3) <E92A145C-2B76-39D1-B481-B7C95ACBF989> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
    0x7fff2bed6000 -     0x7fff2bedffff  com.apple.CMCaptureCore (1.0 - 82.6) <E0EAD649-4C7A-384E-999B-4D82AA9CDA52> /System/Library/PrivateFrameworks/CMCaptureCore.framework/Versions/A/CMCaptureCore
    0x7fff2bee0000 -     0x7fff2bf27fff  com.apple.print.framework.PrintCore (16.1 - 531.1) <035969B9-3323-3AF4-AC4C-1D5B941C7C62> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
    0x7fff2bf28000 -     0x7fff2bff5fff  com.apple.TextureIO (3.10.9 - 3.10.9) <4B778275-5F2D-36DA-A6AD-14C8E516E197> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
    0x7fff2bff6000 -     0x7fff2bffefff  com.apple.InternationalSupport (1.0 - 61.1) <56A6D4F8-FF5B-3F34-BD1A-249414F182E9> /System/Library/PrivateFrameworks/InternationalSupport.framework/Versions/A/InternationalSupport
    0x7fff2bfff000 -     0x7fff2c079fff  com.apple.datadetectorscore (8.0 - 674) <CDA8DABD-62A3-3E1C-9A76-B00E1E950254> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
    0x7fff2c07a000 -     0x7fff2c0d7fff  com.apple.UserActivity (439 - 439) <C272F369-1086-317C-A4CF-AE2E1EC4FFB4> /System/Library/PrivateFrameworks/UserActivity.framework/Versions/A/UserActivity
    0x7fff2cd45000 -     0x7fff2cd76fff  libSessionUtility.dylib (76.69) <400DF595-A30C-3AD3-A8BA-25260299ACE6> /System/Library/PrivateFrameworks/AudioSession.framework/libSessionUtility.dylib
    0x7fff2cd77000 -     0x7fff2ceabfff  com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <93226BB9-165F-3A42-8EE3-9670394C4DC9> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
    0x7fff2ceac000 -     0x7fff2cf11fff  com.apple.audio.AudioSession (1.0 - 76.69) <ADC1C8FC-A444-3F15-A396-B4AB688BB326> /System/Library/PrivateFrameworks/AudioSession.framework/Versions/A/AudioSession
    0x7fff2cf12000 -     0x7fff2cf24fff  libAudioStatistics.dylib (27.64) <74E8B615-03FE-327B-A8FB-EAC5EF117414> /usr/lib/libAudioStatistics.dylib
    0x7fff2cf25000 -     0x7fff2cf34fff  com.apple.speech.synthesis.framework (9.0.66 - 9.0.66) <CE36276F-23DD-32A3-9863-D3A5DDE5965E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
    0x7fff2cf35000 -     0x7fff2cfa1fff  com.apple.ApplicationServices.ATS (377 - 516) <6E601872-2340-3675-9B6F-0C1DB991C54E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
    0x7fff2cfa2000 -     0x7fff2cfbafff  libresolv.9.dylib (68) <86A4BABF-3EFC-3113-BE8A-2D1AAAEF0194> /usr/lib/libresolv.9.dylib
    0x7fff2d0ed000 -     0x7fff2d1ccfff  libSMC.dylib (20) <CF88A94C-B5EE-306F-96A3-1442BA061C46> /usr/lib/libSMC.dylib
    0x7fff2d1cd000 -     0x7fff2d22cfff  libcups.2.dylib (494.3) <2CE9752F-8763-3456-83CF-E4BCFB731153> /usr/lib/libcups.2.dylib
    0x7fff2d22d000 -     0x7fff2d23cfff  com.apple.LangAnalysis (1.7.0 - 254) <AB67008E-5986-3974-B986-FDBFAC018CAB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
    0x7fff2d23d000 -     0x7fff2d247fff  com.apple.NetAuth (6.2 - 6.2) <B5806BA7-9A6E-37A0-9AB9-6EC2D61844AC> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
    0x7fff2d248000 -     0x7fff2d24ffff  com.apple.ColorSyncLegacy (4.13.0 - 1) <86D9E9C9-C631-371E-824E-A203FE9E560A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy
    0x7fff2d250000 -     0x7fff2d25bfff  com.apple.QD (4.0 - 416) <1D8792FC-4A76-3B4F-82CF-3889C05768FE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
    0x7fff2d25c000 -     0x7fff2d8b0fff  com.apple.audio.AudioResourceArbitration (1.0 - 1) <C97CD66B-8267-3C39-B025-789864237928> /System/Library/PrivateFrameworks/AudioResourceArbitration.framework/Versions/A/AudioResourceArbitration
    0x7fff2d8b1000 -     0x7fff2d8bcfff  com.apple.perfdata (1.0 - 67.40.1) <10E2B0C5-83A4-368A-B972-7AFA40D5338C> /System/Library/PrivateFrameworks/perfdata.framework/Versions/A/perfdata
    0x7fff2d8bd000 -     0x7fff2d8cbfff  libperfcheck.dylib (41) <A2D0E1A8-A98F-3DAA-B9FC-C033FC4CD9E0> /usr/lib/libperfcheck.dylib
    0x7fff2d8cc000 -     0x7fff2d8dbfff  com.apple.Kerberos (3.0 - 1) <0074E20F-E7D8-31F5-AF41-0D7BF370CD50> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
    0x7fff2d8dc000 -     0x7fff2d92cfff  com.apple.GSS (4.0 - 2.0) <D546E52C-295F-3CCD-9925-03632FE72ECB> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
    0x7fff2d92d000 -     0x7fff2d93dfff  com.apple.CommonAuth (4.0 - 2.0) <DF20551B-1514-39B3-A52E-681A2E5F0D1C> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
    0x7fff2d993000 -     0x7fff2d9b2fff  com.apple.security.KeychainCircle.KeychainCircle (1.0 - 1) <C48DA26A-6A69-3497-B94D-43332354162B> /System/Library/PrivateFrameworks/KeychainCircle.framework/Versions/A/KeychainCircle
    0x7fff2d9b3000 -     0x7fff2d9bbfff  com.apple.CorePhoneNumbers (1.0 - 1) <9F49D632-C5F4-37F5-A2A8-2830A7560138> /System/Library/PrivateFrameworks/CorePhoneNumbers.framework/Versions/A/CorePhoneNumbers
    0x7fff2db0e000 -     0x7fff2db0efff  liblaunch.dylib (2038.120.1) <4A353070-A560-3A98-8869-28C92435C6B2> /usr/lib/system/liblaunch.dylib
    0x7fff2e2f0000 -     0x7fff2e43bfff  com.apple.Sharing (1630 - 1630) <CE657A48-7BDD-34D7-9CBC-B1D6AD94B2B2> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
    0x7fff2e43c000 -     0x7fff2e55dfff  com.apple.Bluetooth (8.0.5 - 8.0.5d7) <D011494A-287B-3487-B817-2329843C2486> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
    0x7fff2e577000 -     0x7fff2e5d0fff  com.apple.ProtectedCloudStorage (1.0 - 1) <EA0958A6-8296-3E23-81BE-297473A6E17E> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
    0x7fff2fd38000 -     0x7fff2fd5ffff  com.apple.RemoteViewServices (2.0 - 163) <7DBF2A51-CE8E-352E-9426-B83DC370ADDD> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
    0x7fff2fd60000 -     0x7fff2fd6ffff  com.apple.SpeechRecognitionCore (6.1.25 - 6.1.25) <076E6A5F-4FEE-378B-9DCD-AFFA1348C64F> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
    0x7fff2fd70000 -     0x7fff2fd77fff  com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <DB80BAB9-5E83-32DB-A424-05BB19044665> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
    0x7fff2ffa5000 -     0x7fff2ffa5fff  libsystem_product_info_filter.dylib (8.40.1) <78928329-DD98-3799-989D-870DF92FE8D5> /usr/lib/system/libsystem_product_info_filter.dylib
Rabidreject
it made me do it in two.....
Code: Select all
    0x7fff3007d000 -     0x7fff3007dfff  com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <CDB56324-715E-3223-903F-EEC1D4E57F14> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
    0x7fff300a3000 -     0x7fff300a3fff  com.apple.CoreServices (1122.44 - 1122.44) <104E1757-7D8A-32D3-9B38-B23B1A8EAB17> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
    0x7fff3025f000 -     0x7fff3025ffff  com.apple.Accelerate (1.11 - Accelerate 1.11) <28463942-495F-3231-9348-32ABC601A1F5> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
    0x7fff30aa1000 -     0x7fff30b06fff  com.apple.CoreBluetooth (1.0 - 1) <32288DE3-BD59-35A6-9165-73176E074499> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
    0x7fff30b07000 -     0x7fff30b10fff  com.apple.SymptomDiagnosticReporter (1.0 - 79.120.1) <9A1589E7-0B3A-3DC5-967C-7A3D4C14ED1E> /System/Library/PrivateFrameworks/SymptomDiagnosticReporter.framework/Versions/A/SymptomDiagnosticReporter
    0x7fff30b24000 -     0x7fff30b30fff  com.apple.AppleIDAuthSupport (1.0 - 1) <C391F5AD-7903-31AF-8608-7826C0EFB3C5> /System/Library/PrivateFrameworks/AppleIDAuthSupport.framework/Versions/A/AppleIDAuthSupport
    0x7fff30b31000 -     0x7fff30bd9fff  com.apple.DiscRecording (9.0.3 - 9030.4.5) <08A9AAA6-7057-3105-BDE1-DC7270C38774> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
    0x7fff30bda000 -     0x7fff30c0dfff  com.apple.MediaKit (16 - 927.40.2) <86B948D3-5757-37A7-B2DA-F7C50778B108> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
    0x7fff30c0e000 -     0x7fff30cf9fff  com.apple.DiskManagement (14.0 - 1733.140.2) <CF6680B9-9799-3DE8-A600-094260672A4F> /System/Library/PrivateFrameworks/DiskManagement.framework/Versions/A/DiskManagement
    0x7fff310e7000 -     0x7fff31236fff  com.apple.FileProvider (349.4.3 - 349.4.3) <E07C8909-299C-3696-BD84-5CF42EE64EE4> /System/Library/Frameworks/FileProvider.framework/Versions/A/FileProvider
    0x7fff31237000 -     0x7fff31259fff  com.apple.GenerationalStorage (2.0 - 323) <9E36AF92-10E2-382B-A07C-4E3270448690> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
    0x7fff31b95000 -     0x7fff31bd0fff  com.apple.DebugSymbols (195.1 - 195.1) <7D2E32A0-DB93-36EE-AE9C-7974708CF4FC> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
    0x7fff31bd1000 -     0x7fff31c86fff  com.apple.CoreSymbolication (12.5 - 64544.81.1) <7215543C-E3B6-30A0-8B21-7FBDFB10F198> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
    0x7fff32b95000 -     0x7fff32bf8fff  com.apple.framework.Apple80211 (17.0 - 1728) <D89EA57A-D351-3BD1-A470-505C6D8BF4D6> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
    0x7fff32bf9000 -     0x7fff32d4afff  com.apple.CoreWiFi (3.0 - 341) <0FE4018E-E199-3923-A56D-430E40F5EEB7> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
    0x7fff33028000 -     0x7fff3302bfff  com.apple.help (1.3.8 - 71) <CF14979A-CA27-32D1-A3E8-D99AD6C91464> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
    0x7fff3302c000 -     0x7fff33033fff  com.apple.EFILogin (2.0 - 2) <77A5D3D5-3B8D-3B5D-A1BD-A7614C86AF67> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
    0x7fff33034000 -     0x7fff3303ffff  libcsfde.dylib (554.140.2) <8B6A31B3-9421-3BAE-882B-8BEF5217E251> /usr/lib/libcsfde.dylib
    0x7fff3327e000 -     0x7fff3327efff  com.apple.ApplicationServices (48 - 50) <52BB5EB6-2C1B-34F9-8665-F50DD078E71B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
    0x7fff33593000 -     0x7fff33593fff  libHeimdalProxy.dylib (79) <A1B83B1E-006D-38A8-8878-FD6ECBBB9B1B> /System/Library/Frameworks/Kerberos.framework/Versions/A/Libraries/libHeimdalProxy.dylib
    0x7fff33646000 -     0x7fff33646fff  com.apple.audio.units.AudioUnit (1.14 - 1.14) <0A5BB3A7-D9DC-346C-9FBB-FB075194E7AC> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
    0x7fff34616000 -     0x7fff34666fff  com.apple.ChunkingLibrary (334.1 - 334.1) <2CD91198-1354-357F-8858-D58244526C15> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
    0x7fff34f45000 -     0x7fff34fb0fff  com.apple.audio.midi.CoreMIDI (2.0 - 88) <741CCF53-3F51-39A5-B07A-3C14BED77D44> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
    0x7fff35076000 -     0x7fff35079fff  com.apple.Cocoa (6.11 - 23) <237F7F6E-E7D1-363A-92AF-32B564728891> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
    0x7fff36512000 -     0x7fff36535fff  com.apple.openscripting (1.7 - 190) <A2516A00-ECC2-31F2-9157-90AF9A4C6F56> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
    0x7fff36536000 -     0x7fff36539fff  com.apple.securityhi (9.0 - 55008) <DDAD2F6D-2105-370E-9C96-63ABF95ABF00> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
    0x7fff3653a000 -     0x7fff3653dfff  com.apple.ink.framework (10.15 - 227) <6177BDED-F304-3EAD-B72E-23A050856753> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
    0x7fff3653e000 -     0x7fff36541fff  com.apple.CommonPanels (1.2.6 - 101) <E6BB8219-34DB-3A11-A3C2-B17AD8E42414> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
    0x7fff36542000 -     0x7fff36549fff  com.apple.ImageCapture (1711.5.2 - 1711.5.2) <E3871995-745C-35A8-8B48-647DAAF046E1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
    0x7fff3caa3000 -     0x7fff3caa6fff  com.apple.print.framework.Print (15 - 271) <29E7EB03-0307-35D9-B56F-B9DCB5C5A4E7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
    0x7fff3caa7000 -     0x7fff3caaafff  com.apple.Carbon (160 - 164) <B86E3835-F4BE-3DCA-88C7-CEA01227DF58> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
    0x7fff3cd5d000 -     0x7fff3cd7cfff  com.apple.private.SystemPolicy (1.0 - 1) <8BC55621-1E45-33B3-BCD6-C59F1F390695> /System/Library/PrivateFrameworks/SystemPolicy.framework/Versions/A/SystemPolicy
    0x7fff3d4e8000 -     0x7fff3d4effff  com.apple.HIDAnalytics (1.0 - 1) <16D37741-EB4F-3D3F-930F-98DE723FCEFD> /System/Library/PrivateFrameworks/HIDAnalytics.framework/Versions/A/HIDAnalytics
    0x7fff3d6ba000 -     0x7fff3d6ccfff  libmis.dylib (274.140.2) <570E2D9A-BC76-37F7-8CFC-E18AD5E81CE0> /usr/lib/libmis.dylib
    0x7fff3d6cd000 -     0x7fff3d6d0fff  com.apple.gpusw.GPURawCounter (20.3 - 12.0) <9463CB15-1CD3-37D3-9C2E-1C96A895F8A5> /System/Library/PrivateFrameworks/GPURawCounter.framework/Versions/A/GPURawCounter
    0x7fff41381000 -     0x7fff4139ffff  libCGInterfaces.dylib (544.4) <05A5B7E9-C79A-3FEA-AD6C-72FE168004C3> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
    0x7fff5ddf8000 -     0x7fff5e287fff  com.apple.driver.AppleIntelKBLGraphicsMTLDriver (16.5.2 - 16.0.5) <DD84C8FF-1113-396A-A1DA-F95347B51B19> /System/Library/Extensions/AppleIntelKBLGraphicsMTLDriver.bundle/Contents/MacOS/AppleIntelKBLGraphicsMTLDriver
    0x7fff697b9000 -     0x7fff697bdfff  libmetal_timestamp.dylib (31001.192.1) <408D3E8F-D662-38FF-A0AB-79615D1BBD0D> /System/Library/PrivateFrameworks/GPUCompiler.framework/Versions/31001/Libraries/libmetal_timestamp.dylib
    0x7fff6bc04000 -     0x7fff6bc0afff  libCoreFSCache.dylib (200.11) <3C96E791-3964-32EA-A84A-00DF3455B43D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
    0x7fff6bc0b000 -     0x7fff6bc0ffff  libCoreVMClient.dylib (200.11) <966F49F6-D2D5-3ACB-9CFD-9F8D3C8C82F9> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
    0x7fff6bc10000 -     0x7fff6bc1ffff  com.apple.opengl (18.5.9 - 18.5.9) <5C26B170-E22B-3AAD-BA33-61304FFA70B2> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
    0x7fff6bc20000 -     0x7fff6bc22fff  libCVMSPluginSupport.dylib (18.5.9) <435F258D-95B5-3015-BDAC-4B8EF8E89F1E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
    0x7fff6bc23000 -     0x7fff6bc2bfff  libGFXShared.dylib (18.5.9) <851E0956-A16E-3F5D-B3BE-37B56C2BAA04> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
    0x7fff6bc2c000 -     0x7fff6bc5ffff  libGLImage.dylib (18.5.9) <687EBB15-1AB3-3815-A69D-58527655A92D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
    0x7fff6bc60000 -     0x7fff6bc9cfff  libGLU.dylib (18.5.9) <29B7802C-F6E4-3DF1-B5D6-07B29C6D02B2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
    0x7fff6be31000 -     0x7fff6be3bfff  libGL.dylib (18.5.9) <8A4ED04C-9171-3CE2-A52A-E7C4D76A6EDA> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
    0x7fff6d27b000 -     0x7fff6d2d3fff  com.apple.opencl (4.6 - 4.6) <713206B3-A335-3AC5-B342-4CE16BDF69F4> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
    0x7fff77aaf000 -     0x7fff77ab6fff  libRosetta.dylib (203.58) <F72C2D50-7279-3497-8A59-56908F9661F3> /usr/lib/libRosetta.dylib
External Modification Summary:
  Calls made by other processes targeting this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by all processes on this machine:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=697.5M resident=0K(0%) swapped_out_or_unallocated=697.5M(100%)
Writable regions: Total=605.4M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=605.4M(100%)
                                VIRTUAL   REGION
REGION TYPE                        SIZE    COUNT (non-coalesced)
Accelerate framework               384K        3
Activity Tracing                   256K        1
CG backing stores                 1080K        6
CG image                            24K        4
CoreAnimation                      336K       36
CoreGraphics                         4K        1
CoreUI image data                  448K        8
Foundation                          16K        1
Kernel Alloc Once                    8K        1
MALLOC                           206.9M       59
MALLOC guard page                   32K        8
MALLOC_NANO (reserved)           384.0M        1         reserved VM address space (unallocated)
STACK GUARD                       56.0M        9
Stack                             12.1M        9
VM_ALLOCATE                        108K       19
__DATA                            13.0M      297
__DATA_CONST                      11.8M      169
__DATA_DIRTY                       541K       99
__FONT_DATA                          4K        1
__LINKEDIT                       501.1M       11
__OBJC_RO                         70.3M        1
__OBJC_RW                         2496K        2
__TEXT                           196.5M      302
__UNICODE                          588K        1
mapped file                      254.8M       33
shared memory                      752K       14
TOTAL                              1.7G     1096
TOTAL, minus reserved VM space     1.3G     1096
Model: Macmini8,1, BootROM 1554.140.20.0.0 (iBridge: 18.16.14759.0.1,0), 4 processors, Quad-Core Intel Core i3, 3.6 GHz, 8 GB, SMC
Graphics: kHW_IntelUHDGraphics630Item, Intel UHD Graphics 630, spdisplays_builtin
Memory Module: BANK 0/ChannelA-DIMM0, 4 GB, DDR4, 2667 MHz, Micron, 4ATF51264HZ-2G6E3
Memory Module: BANK 2/ChannelB-DIMM0, 4 GB, DDR4, 2667 MHz, Micron, 4ATF51264HZ-2G6E3
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x7BF), wl0: Aug 10 2021 19:55:28 version 9.30.444.18.32.5.71 FWID 01-93db3422
Bluetooth: Version 8.0.5d7, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en1
USB Device: USB 3.1 Bus
USB Device: eDrumIn BLACK
USB Device: SAMSUNG_Android
USB Device: BillBoard Device
USB Device: Scarlett 2i2 USB
USB Device: eDrumIn BLUE
USB Device: Apple T2 Bus
USB Device: Headset
USB Device: Apple T2 Controller
Thunderbolt Bus: Mac mini, Apple Inc., 47.5
Re: eDRUMin version 2 Alpha
Rabidreject wrote:
Sun Feb 13, 2022 2:23 pm
also are the cymbals meant to be floor toms in the new version??!
During the change from 20 -> 32 kit pieces, I made changes to the images and how they are identified. You need to send a factory 'drum map' to your device to correct the issue. I can also see that you haven't applied the firmware update (orange !) in the bottom left hand corner.
mprinz wrote:
Sun Feb 13, 2022 9:04 pm
Sun Feb 13, 2022 1:46 pm
You can still roll back to version 1.6 and load them that way. I tested loading a version 1.6 preset in version 2, though, and it seemed to work fine though. I just tested again and it looks like you are right. I will fix it tomorrow.
Hi Rob!
Thank you so far, but anyway when I import the 1.6 device snapshots everything looks kinda weird and
these where not my settings.
So I can load the old 1.6 input presets but not my todays device snapshots from the v2 build before the EPROM thing.
Is it possible to extract the trigger and pedal settings from the device snapshots.
And - yes the cymbals are floortoms ... ;)
Thank-you for the attachments. I will work with them today. After changing from 20 -> 32 kit pieces, drum maps from earlier builds (including those saved as part of a device snapshots) will no longer be compatible. The fix is to load a factory drum map after loading a device snapshot saved in version < 2.0.0.8.
It is technically possible to extract trigger and pedal presets from a device snap shop, but not something I'm willing to consider for version 2.0.
Yup, definitely a bug. Must have cropped up around build 2.0.0.4. I'll fix it today. Unfortunately it's a firmware issue (device sends the wrong data), and any saved version 2 device presets will contain garbage information.
Posted build 11.
  • Fixed issues with saving version 2 device presets.
  • Loading a device preset will now properly refresh the pedal editor.
  • Added 'Version' to preset metadata.
  • Fixed a display bug when changing pad types and input is set to 'Kit piece'.
Rabidreject
Post by Rabidreject »
[/quote]
[/quote]
Oh ok. I’ll load a new preset and start again In terms of mapping to change the image.
Also yeah I took that screenshot way earlier than I posted it and realised I had to update the firmware (again!) so it’s been done. Seems like iv updated firmware a lot but in actual fact I realised I have two devices so maybe it was that.
Anyway, things are great with the new build other than the crashing problem!
Cheers rob, will update again today
