eDRUMin version 2.3 BETA
Re: eDRUMin version 2.3 BETA
The exclamation make means a firmware update is available. Click on the exclamation mark and then click update.
TOP
Post by TOP »
Ok.. I will do it as soon as i get home from work... thanks Rob
TOP
Post by TOP »
hi Rob, i just updated the firmware.. and got RS now for XP80... . tho i notice the placement is a bit inaccurate... between 6-9-12 o'clock it trigger RS when i hit rim only...should i recalibrate? any idea? thanks
It's not related to calibrating. I'll take another look tomorrow. I can tweak the sensitivity.
TOP wrote:
Fri Sep 15, 2023 11:02 am
Isn't that normal behavior for Yamaha pads?
TOP
Post by TOP »
im. not sure iits normal when hitting rim only then produce sound like rimshot(rim+part of center), i think it should be sound of the rim only tho how hard i hit it.. sound clicking like side stick?
I can do that with xp70 preset but its single zone pad and need helped with SD3 velocity gate trick... and for 3 zone xp80 i kind a expect it was default sound, without needing any SD3 tricks
Thanks.
AKA Wayne
Post by AKA Wayne »
Sounds like you need to use the rimshot control. Read about it on theanual. It's easy and very useful.
TOP wrote:
Sat Sep 16, 2023 12:14 am
Thanks.
Then I think you should consider a dual piezo pad, because they work like you'd expect.
AFAIK, I've implemented the Yamaha system correctly (as per the drawing posted above, which you seem to completely ignore) and never had anyone tell me I did it wrong for the past several years.
If you don't like the way it sounds, then go the velocity gate route. Perhaps I'll implement a velocity gate in the future, but have no immediate plans to do so as I would need to make big changes to the UI to support it, and I'd prefer to focus on stability and performance at the moment.
TOP
Post by TOP »
AKA Wayne wrote:
Sat Sep 16, 2023 12:38 am
u meant Square box on the bottom left, Wayne ? i believe its not shows up when using xp80 preset mgr. but thanks for ur attention wayne, really appreciate
TOP
Post by TOP »
Sat Sep 16, 2023 1:09 am
Thanks.
If you don't like the way it sounds, then go the velocity gate route. Perhaps I'll implement a velocity gate in the future, but have no immediate plans to do so.
ok, thanks Rob... XP80 its dual piezzo pad right?
