Well I'm making progress....I'll look into that last issue tomorrow. Thanks for your patience.
Another crash, similar as the last one. Trying to quit out of the app by using the red 'x' button in MacOS.
edrumin_crashreport_052121.txt.zip
(22.41 KiB) Downloaded 130 times
https://www.audiofront.net/eDRUMin_Cont ... 5.0.11.zip
Changes in build 11
  • Fixed changing hihat note bank not triggering autoSave
  • Fixed an issue that could cause factory presets not to show up on Windows if not an administrator.
  • Probably fixed an issue that could cause a crash when close the OSX control app.
Alx_d
Post by Alx_d »
Now I have a request for an enhancement unless it already exists which if it does then please show me the way.
I would like to be able to select an input and then go to the preset manager page and see which preset was loaded for the given trigger input (EX: Factory>Roland>Drum>PD125) . I always wind up resetting the input and selecting the trigger again. Only a few days later to forget which one it was that I had selected yet again.
Thank you for all the the quick fixes and responses! I have never seen this before with any company small or large. Please keep up the most excellent work.
Can't be done.
Rob wrote:https://www.audiofront.net/eDRUMin_Cont ... 5.0.11.zip
Changes in build 10
Fix Confirmed. Thanks!
https://www.audiofront.net/eDRUMin_Cont ... 5.0.12.zip
Changes in build 12
  • Fixed an issue where ED10R2 could report being an ED10 after changing the device color
Don't try to update presets by overwriting them. This will corrupt pedal presets and device presets. I'll fix it tomorrow.
https://www.audiofront.net/eDRUMin_Cont ... 5.0.13.zip
Changes in build 13
  • Fixed several issues with saving / loading / updating presets
  • Doubled the max USB Host descriptor size (possible fix for Alesis Module)
crash report. I was updating firmware to 1.5.0.13 beta. The last screen I saw before it crashed said it was rebooting the unit. I didn't see the programming progress. I was afraid I bricked it. When I tried to open the app it opened and them immediately closed. I think this happened twice over about 30 seconds. Then I paused another 30 seconds. Opened it again and the app opened. I looked at the firmware screen and the unit is at the latest firmware. Did not brick. So no issues.
1.5.0.13 beta update crash.zip
(19.72 KiB) Downloaded 109 times
