eDRUMin version 1.3.2 BETA
Changes in build 11
  • Fixed note controls not properly updating when entering in a value using the keyboard (since build 7).
I've also posted this one on the main downloads page.
No need to update firmware of the devices?
Nope. Firmware is still build 9.
monospace wrote:Minor bug in current version (build 7) : Auto-select doesn’t switch between triggers on ED10 and ED4. Works fine if you start with a trigger on the ED4 and then play one connected to the ED10, but not the other way around.
Bumping this up as it’s still not functioning properly in the latest version.
I'm unable to reproduce the issue on Windows. Maybe be it's only a mac thing (very unlikely). This is what I tried.
1. Unplug ED10 (with ED4 connected to the back)
2. Replug ED10.
3. Open the control application.
4. Hit a pad on ED4.
5. Hit a pad on ED10.
6. Hit a pad on ED4.
This all worked as expected, and auto select switches between devices.
I repeated the same test on macOS without issue. Can you see if you can reproduce the issue by following the same steps?
Not trying to change the subject or pile on but this is what started happening for me with build 8. In the video I’m just tapping back and forth on each device. This video is made with build 11.
My red device is all mesh head pads. My black device is all cymbals, input 1 & 2 are hi-hats, and input 10 is not used. You can see the pad buttons are not updating properly.
As far as I can tell the devices are working just fine when playing.
https://youtu.be/DnNfUOLcfeI
Mylo, I was seeing a similar issue with earlier builds, but I made a small change in build 8 or 9 that fixed it on my system, but seems to be having the reverse affect on yours? You're absolutely sure that video was made using build 11?
Yes. On Windows 10.
Here's build 12, in which I've undone the change. Can you see if it resolves the issue. No changes to the firmware BTW.
PC
http://www.audiofront.net/eDRUMin_Contr ... 3.2.12.zip
