eDRUMin version 2.3 BETA
TOP
Re: eDRUMin version 2.3 BETA
Post by TOP »
Tue Sep 12, 2023 4:49 am
Flash memory (completely optional) can be used to save device presets, which can be loaded using a footswitch (without needing to open the control application). 95% of people don't need this feature, and instead should save / load device snapshots the normal way via the control application on their computer.
Ok, thanks Rob... so if i dont use flashdisk, that mean i should open edrumin control software in my PC.. everytime and as long as i use my vst drum?
Inferior Drummer wrote:
Sun Sep 10, 2023 4:52 am
It certainly is a hard to make happen issue. I Had hoped that I narrowed down the firmware versions with and without the problem enough that you would be able to figure what changed.
It was still happening on the latest version. May be not as much?
Could there be something else that changed that might necessitate re-calibrating the closed position or something? I kind of have been meaning to find the time to redo all edrummin settings from scratch. Some times the first time/way you set something isn't the best...
If there is anything I can do to help.
Cheers.
Can you give build 7 a try.
eDRUMin_Control_PC_2.3.0.7.zip
eDRUMin_Control_OSX_2.3.0.7.zip
TOP wrote:
Tue Sep 12, 2023 5:56 am
No, that would be a horrible limitation. The manual has lots of information.
Getting Started
After rereading the Preset Manager section in the manual, I can see that it's a bit confusing. I'll have to add another page to that section can explain things more carefully.
Here's a video with more info
https://www.youtube.com/watch?v=7KOHNrTnmYM
TOP
Post by TOP »
Ok thanks Rob... ill studying after come from work,
and sinve theres nee version ED Control that is 2.3.7 u posted in this forum.. thats wha i will download today right?
Sorry for overwhelming questions, i just need to get everything right as it should..
thanks again
Inferior Drummer
Post by Inferior Drummer »
Ahhh no rest for the wicked! Thanks Rob!
Tue Sep 12, 2023 4:51 am
So I did a quick test and I was able to see an issue. An example is shown below. Not entirely sure why it's happening, but I'll see if I can fix it.
hehe I think I understand that pic enough to recognise it looks like the issue :lol:
Tue Sep 12, 2023 6:17 am
I'll have a quick play around now. Cheers.
TOP wrote:
Tue Sep 12, 2023 6:48 am
thanks again
I'd recommend the latest, very few if any "bugs" and Rob's doesn't mess around when it comes to fixing things asap.
EDIT: A rather brief and drunken bash admittedly, but things seem great Rob. It even passed my test of attempting to play Primus' version of Silly Putty. It's Bark City!
https://www.youtube.com/watch?v=W_RaWhq7W9w
Thanks again Rob.
TOP
Post by TOP »
okay... im at home
-unboxing ED8
-put it on dtx700 rack
-connect my xp80 to ED8
-connect my ED8 to PC
-Turn ON my PC
-Installing ED Control 2.3.0.7
-open Stand alone SD3
-check ED Black as input midi device on SD3
-choose Yamaha XP80 from preset Manager
-hitting the pad.. and NO SOUND
-Clicking drum icon on SD3... n theres Sound (So SD3 n my PC are fine)
-try to calibrate.. and theres signal in ED Control (So ED8 sent signal to ED Control on my PC)
-set drum map to Superior drummer map
- try hitting the pad again... still no sound
-looking for tutorial in manual n video bout connecting ED to SD3.. havent found yet
So... Anybody kind enough to enlight this newbie plz???
Thanks in advance
This is the wrong place to post, but did you make sure SD3 and the eDRUMin are using the same drum map?
TOP
Post by TOP »
TOP wrote:
Tue Sep 12, 2023 12:19 pm
okay... im at home
-unboxing ED8
-Turn ON my PC
Thanks in advance
update : Cick Firmware icon "Downgrade button" shows up (The Firmware on this device is hogher than the installed firware)....is it normal?
That's probably a small bug. Ignore it.
TOP
Post by TOP »
Tue Sep 12, 2023 12:32 pm
ups ..sorry... i think im litle panic here...where the proper place?
if u mean by "SD3 and the eDRUMin are using the same drum map" are set select drum map in ED Control as Superior Drummer Map, and choosing eDrumin Black as midi inpu on SD3... then YES I did... i cant find Edrumin preset on SD3 yet...so i put as default
