- Pedal Sensing will continue to function when a pedal / hihat controller is disconnected and reconnected but the cable remains plugged into the pedal input.
- Inadvertent bank changes are prevented when a footswitch or sustain pedal is disconnected.
- Fixed small issues with momentary footswitches.
eDRUMin version 1.3.1 BETA
Re: eDRUMin version 1.3.1 BETA
Changes in build 6
I’m already on 1.3.1.5. Is this supposed to be 1.3.1.6?Rob wrote:Changes in build 5
Yup, it's supposed to be build 6. I've updated the first post.
All good now. Thanks.Rob wrote:Yup, it's supposed to be build 6. I've updated the first post.
There's now a dual zone metal cymbal pad type to choose from, it works perfectly with my diamond drum low volume zildjian dual zone crashes with choke
Build 6: with the Pedal editor screen open while playing, the display is cycling between the 4 different pedal modes. Not all the time, it’s rather random. Doesn’t appear to affect playability, but looks a bit disconcerting.
Okay. You are using a vh11 right. Better disable pedal sensing for the time being.
I’ve got a VH-10, if it matters. Pedal sensing was turned off already, but I switched it back on, then off again, to be sure. Seems to resolve the issue.
- dsteinschneider
Haven't testing the unplugging the hi-hat pedal but noticed the issues before. I usually power cycled the eDRUMin if I did anything with the pedal.
- dsteinschneider
