Hi Dadwrshpdrum,
hi Rob,
hi buddies,
that's quite funny, since I worked on the exact same libraries.
Dadwrshpdrum wrote: ↑Tue Feb 08, 2022 12:09 am
So, I just spent some time this weekend creating SD3 drum maps for Fields of Rock both for two Tom configs and three Tom configs, Gospel EZX and the the core library etc…. With V2 I could have done the same thing within eDRUMin, and left the user presets alone in SD3.
Sorry, but I was actually thinking about those eDRUMin drum maps.
I don't know, was it a desired feature? I mean, it is actually really helpfull for all guys playing the edrums, and
don't have a DAW or sample software available that could remap MIDI notes, yes. I had to buy Plogue Bidule to perform those settings
without a DAW and EZDrummer2.
I mean, with that kit parts approach you don't have that fiddling with notes and which is for SS, which is for HIT, RS, CC ... Or - only once.
But I have to change my drum sampler library anyway, so...
So, I decided to go the SD3-MIDI-in-mapping way, like Dadwrshpdrum.
Is there any disadvantage doing this? I mean, I find like the library MIDI mapping on SD3 is not that consistent or easy to manage.
Fields of Rock / Percussion or the Rooms of Hansa with the rototoms and octobans. Even - as he said the "simple" Gospel EZX...
Not least because I want to have the note bank feature, with that I can switch between intruments without any loading times.
But I have to assign/create these intruments in SD3 before. Let's say, the 1st floor tom changes to a fat, big snare. The octobans to rototoms, sidesnare to 5th tom.
- edrums.JPG (533.07 KiB) Viewed 1839 times
Besides that: The best new feature is the PDF button on the left side of the "plug in your eDRUMin".
EDIT: And of course the MIDI Monitor. The HiHat engine. The Yamaha 3-Zone fix (yeaheee) AND I really like those fancy virtual LED flashing in the USB Host Port Config, I wish there would be a kind of summarized view seeing all inputs with LEDs for the different zones and meters ... awwww, nice.
Thank you Rob! Amazing!
