eDRUMin 1.6.2 BETA
Re: eDRUMin 1.6.2 BETA
I think this is ultimately a non-issue because simply adjusting the rimshot range takes care of the problem--which explains why we're not seeing others complaining of problems. You are right though, you can dial in much more aggressive rimshot range thresholds when auto-select is disabled. I would have thought closing the app would reduce the overall noiselevel, but that doesn't seem to be the case. I'll spend some time this week investigating.
Definitely an issue--fixed for the next build.
This fixes a bug that could cause low velocity head hits to turn to sidestick or rimshot.
eDRUMin_Control_PC_1.6.2.5.zip
eDRUMin_Control_OSX_1.6.2.5.zip
I played a bit tonight and couldn’t find any issues like I had before. I would consider it fixed. Thanks!Rob wrote: ↑Wed Dec 15, 2021 5:09 amThis fixes a bug that could cause low velocity head hits to turn to sidestick or rimshot.
eDRUMin_Control_PC_1.6.2.5.zipeDRUMin_Control_OSX_1.6.2.5.zip
I've just upgraded to 1.6.2.5 and I'm having an issue where side mounted piezo, mesh snare pad profile is sending CC Pan data with every hit. Doesn't happen if I change it to a rubber pad profile.
Confirmed. Crap. I was using that CC to do some debugging and forgot to remove the debugging code.
Fixed an issue where dual piezo pads were sending CC10.
eDRUMin_Control_PC_1.6.2.6.zip
eDRUMin_Control_OSX_1.6.2.6.zip
I’ve noticed since the latest fix a xtalk issue between rimshot and BT1 (sensor mode - xtalk 33) that wasn’t there before. While I’m playing rimshot backbeats about every fourth measure or so a high velocity sidestick (from BT1) is triggered. I have some screenshots I can share later today.
Here are three screenshots. This is with auto select off. There is a screenshot from the beginning of the event, the middle of the event, and at the end of the event.Dadwrshpdrum wrote: ↑Mon Dec 20, 2021 7:04 pmI’ve noticed since the latest fix a xtalk issue between rimshot and BT1 (sensor mode - xtalk 33) that wasn’t there before. While I’m playing rimshot backbeats about every fourth measure or so a high velocity sidestick (from BT1) is triggered. I have some screenshots I can share later today.
- BT1 SS autoselect off mistrigger end of event.png (268.47 KiB) Viewed 1102 times
- BT1 SS autoselect off mistrigger.png (257.15 KiB) Viewed 1102 times
- BT1 SS autoselect off mistrigger beginning of event.png (256.13 KiB) Viewed 1102 times
And here are two more screenshots with auto select on.Dadwrshpdrum wrote: ↑Mon Dec 20, 2021 7:04 pmI’ve noticed since the latest fix a xtalk issue between rimshot and BT1 (sensor mode - xtalk 33) that wasn’t there before. While I’m playing rimshot backbeats about every fourth measure or so a high velocity sidestick (from BT1) is triggered. I have some screenshots I can share later today.
- BT1 SS autoselect on at end of mistrigger.png (286.98 KiB) Viewed 1101 times
- BT1 SS autoselect on beginning of mistrigger.png (275.69 KiB) Viewed 1101 times
