Latency
Denis
Re: Latency
Post by Denis »
Does anyone know if 1 eDRUMin10 creates less latency than 1 eDRUMin4 connected to an eDRUMin8 module (host)?
Re: Latency
Hi Denis,
for me it's still not clear how this is managed. All the gamers are complaining about their high keyboard input latency.
Talking about above 5ms.
Right now I've read that USB MIDI uses the bulk transfer protocol and that means polling is at a much increased rate.
I checked the latency with the eDRUMin10 connected through a hub and without, with USB sticks copying large files through the same
bus... no *noticeable* increased latency. I did not perform detailed masurements.
Maybe Rob can comment on this, but I think you will be fine!
Denis
Re: Latency
Post by Denis »
Thank you mprinz for trying to answer the question! In another thread, Rob said that this combination doesn't create more latency.
